OBD II readiness?
Old Aug 15, 2011 | 09:21 AM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
OBD II readiness?
Okay so I have had this on going issue of not being able to pass emmissions with my car. The problem is that my obd II is not showing readiness. I have driven the car close to a 1000 miles this weekend and still no luck. Is there anyway to use the durametric tool to set the car in ready mode or another procedure in order to have the car ready to test. I need to either pass or fail. Even if I fail I can get a waiver but since the system is not ready I am getting rejected. The 3 systems that are not ready is:
1) cat conv.
2)o2 heater
3) secondary air.
I have had several shops check for hardware issues and none found anything. Tony at EPL said its not in his tune. So now what? Has anyone else experienced this?
Old Aug 15, 2011 | 09:59 AM
sweeney186's Avatar
sweeney186 is infamous around these parts
Had the same issue w/ my epl tune,sent it back to epl,drove it a bit & passed w/ nothing else done
Old Aug 15, 2011 | 10:07 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
I had this happen on my e46 with an AA kit. Basically, some tuners shut off the o2 monitoring (where the ecu adjusts fuel based on o2 sensor reading). They rely on the map, otherwise the car will run too rich / lean, etc.
I had it turned back on for emissions, car ran pig rich, then disabled it again afterward and all was well.
Not sure if it's the same case with EPL or the 996 in general, but it sounds very similar.
Old Aug 15, 2011 | 10:48 AM
007-911's Avatar
I asked Tony at epl about this. He claims that none of those things are shut off.
Old Aug 15, 2011 | 11:00 AM
aren't your o2s off? maybe just the post cat?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 15, 2011 | 12:20 PM
sweeney186's Avatar
No disrespect to Tony,but he told me the same thing.I verified readniness prior to the flash & all 5 monitors were ready & passed.After flash-only 2 monitors ready & passed-did full tank,in town,freeway driving,overnight etc-could not get readiness.Took a couple of calls to convince them.
Old Aug 15, 2011 | 12:45 PM
daytrip00's Avatar
daytrip00 is infamous around these parts
I had this issue on my stock tune. What you're going to have to do (or at least what I had to do) is go through a few drive cycles. Here's the one I used:
BMW Drive Cycle
The thing you'll have to do is keep your revs below 3000 rpm. It's excruciatingly painful, but that should make it work. I've driven 2000 miles without my Cats being ready because going above 3000 revs cancels the cycle. The other thing, for your secondary air, start it up and let it idle for a couple minutes before you drive (again keeping the revs below 3000 rpm). For the O2 sensors, let it idle for a few minutes before you shut it down.
This is what i had to do after having the battery disconnected when I had to get it smogged. I hope this helps!
Old Aug 15, 2011 | 01:00 PM
007-911's Avatar
I think it is the tune too. Tony wants me to ship the car back to him but that’s not exactly in my budget nor do I think that the shops that have looked into my cars are incapable of fixing any hardware issues (AMS, Eurosport, Underground Auto, Barrington motorwerks).
I took the car this morning to try to test it again the guy was nice and did it again. Once again system is not ready because it says those three systems are, "not supported!"
I am having my car retuned on Monday. Hopefully he can set it so that it passes. I will try to do the drive cycle once again as recommended for BWM.
Thank you guys for your feedback. I am open to any other suggestions, I have to get this car registered.
Old Aug 16, 2011 | 08:04 AM
sweeney186's Avatar
Just pull your ECM & ship it.It's not that hard to remove & can be programmed w/o the car.I did mine this way
Old Aug 16, 2011 | 08:24 AM
007-911's Avatar
I can just have EPL send the file to AMS and have them just flash it. However, I need epl to agree that something with the tune can be changed to allow it to be ready.
Old Aug 16, 2011 | 06:02 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i have the same issue, cant get it to pass no matter what i do, just tried another drive cycle (which is a nightmare to do) and that didnt help
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
Oct 27, 2015 04:49 PM
WheelB
Sep 3, 2015 10:26 AM
