oil leak help!
Old Aug 23, 2011 | 12:43 AM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
oil leak help!
Grrrrr. Bought the car 2 weeks ago and it was dry as a bone.
Tonight I notice a dime sized oil drop under the car.
Snapped a pic.... Where do you guys think I should start to be concerned with.
Old Aug 23, 2011 | 07:27 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
First guess would be the dreaded rear main seal. [RMS] Someone probably cleaned it up just prior to the sale. Did you have the car pre-inspected?
Old Aug 23, 2011 | 09:57 AM
ek9max's Avatar
No I didn't. I had 3 different shops looks for oil leaks while the previous owner did tires/alignment/oil change before I took the car.
Old Aug 23, 2011 | 10:14 AM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Oh man, take it in and have it looked at. Good luck.
Old Aug 23, 2011 | 11:19 AM
Ether rear main seal or possibly just a overspill from changing the oil... seen that too...
but Im guessing RMS....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 23, 2011 | 12:06 PM
jpflip's Avatar
The reservoir is over this area on the right of the engine and there is a return line that is connected on the reservoir left side...It can be leaking too.....
Old Aug 24, 2011 | 12:04 AM
ek9max's Avatar
If it is a RMS. Is there a special tool needed to replace this? My mechanic buddy did a c4s, and said a special tool was required.
Old Aug 24, 2011 | 06:32 AM
Slik560's Avatar
Yes. Not just any bearing press tool, but a Porsche tool. I understand that this is a job for someone that specifically does a lot of Porsche work.
Old Aug 24, 2011 | 08:17 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Hey, that's my engine it that picture...!
Old Aug 24, 2011 | 08:27 AM
jpflip's Avatar
If anyone is looking for a picture (mechanically related) that was posted on this site I probably got it!
Old Aug 24, 2011 | 09:41 PM
JoeFerg's Avatar
JoeFerg is infamous around these parts
Dont rule out the IMS bearing. Get the transmission removed and looked at immediately. Have you IMS bearing upgraded with LN Engineering's kit and Rear main oil seal too.
The Porsche RMS tool makes the job very easy. You cant f#$% it up using the correct tool.
EDIT: Ooopps haha, just realized this is the turbo/gt2 section. Disregard my comment on the IMS!
Old Sep 13, 2011 | 10:56 AM
ek9max's Avatar
Just had a thought. This leak started after an oil change.
When I was changing the filter I didn't have the dime sized o-ring that goes on the base of the stem so I reused the old one. If that leaks, where would that oil go?
Old Sep 13, 2011 | 11:15 AM
jpflip's Avatar
A little bit of oil would bypass the filter only without leaking externally....
Old Sep 13, 2011 | 11:50 AM
Tim941NYC's Avatar
No sweat, no special tools needed.. It would be the price to fix as if you where having the clutch and flywheel replaced Plus the cost of the seal.
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
Lucid Moment
Sep 12, 2015 01:12 PM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
ricks234
Sep 10, 2015 12:51 PM
