Hood release broken? No dead battery
Old Oct 9, 2011 | 07:13 PM
silentbob's Avatar
silentbob is infamous around these partssilentbob is infamous around these parts
Solved. I guess I just wasn't pulling hard enough. I grabbed some bigger pliers to get a better grip and more leverage. Was able to really pull hard. This time, the latch mechanism finally popped. Thanks to everyone for the help. I was ready to pull off the bumper and disassemble the mechanism.
Old Oct 9, 2011 | 07:31 PM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
Originally Posted by silentbob
Hi Guys,
Not sure if anyone encountered this before, most hood issues I've found in search appear to be due to dead battery.
My battery is very much alive and I still drive the car. However, the hood release stopped working. I can hear the motor whir when I press the hood release button on the car or on the key, but the "pop" that usually follows from the hood being released does not occur.
Could it be that the cable broke or is off track? Any thoughts on what I should be looking for? It was working fine a few days ago.
I accidentally found the trunk release wire when I had the front off the car cleaning the crap from the radiators last week. I rerouted it via a slit I made in the right hand air scoop next to the temperature sair sensor so that I can reach and pull if ever I should need to in the future. I tried it after I put the front back on and it worked great. You might try that if ever you open youthe lid. Good luck.
Old Oct 9, 2011 | 07:49 PM
jpflip's Avatar
Always good to see a happy ending. Thanks for keeping us inform of the outcome....
Old Jun 23, 2013 | 06:18 AM
JohnnyRocker's Avatar
JohnnyRocker is infamous around these parts
Not a GT2 but my problem sounds similar see link....
https://www.6speedonline.com/forums/...ml#post3878463
Once you opened your hood lid were you able to close it? Does it work fine now? My lock appears broken and won't latch now. It's stuck in the garage until I order a replacement and figure out how to install it.....
PV=nRT.
Sep 9, 2022 06:06 PM
NIKAS
Aug 20, 2019 07:53 PM
gadgetman
Sep 10, 2015 03:29 PM
oo7
Sep 10, 2015 08:08 AM
DetomasoGTS74
Sep 7, 2015 09:42 AM
