Shifter cable?
Old Sep 20, 2011 | 10:32 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Shifter cable?
My car has 80,000 miles now – runs like a dream. However this has now happened to me three times in a last month; when on full throttle and I change from 2nd to 3rd I miss the shift (accompanied with a bit of a grinding noise). It’s like the shifter wants to slot it into 1st! Either I am getting old stupid and imprecise or something went out of sync. I never missed shifts. If I drive normaly it does not happen, only when I rush the shift. Is it possible that shifter cable stretched? Does it go out of adjustment by itself? Do you guys adjust on regular basis? What’s the score here? Thanks.
Old Mar 7, 2012 | 06:34 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Had this lock out happen today. Anybody?
Old Mar 8, 2012 | 06:59 AM
vr4henry's Avatar
Update: went through and realigned my cables with the green 997 tool last night. Found a lock washer a lazy tech let drop when installing the Cup Car cables. Added that to the missing shift end, hopefully it'll stay where it's supposed to now. I'll update back if I get locked out again.
Old Mar 8, 2012 | 12:07 PM
landjet's Avatar
I've had this problem on track, usually when turning and there is a side load on the car. Some think it is from the stock soft motor mounts that allow the motor to shift slightly and affect the cables. Some think it comes from a worn transmission mount. Shifting too fast also seems to contribute to the problem. Henry, I'm surprised that you had this happen with the cup car cables. Only way I have been able to avoid it is by slowing down my 2nd to 3rd gear shift into a diffinite 2 part shift, first to neutral, then into 3rd. You don't need to double clutch but you do have to pause slightly after going into neutral. Hope that helps. My car has the transmission mount upgrade and Wevo motor mounts but will still make a balky shift if I rush it.
Old Mar 8, 2012 | 12:48 PM
vr4henry's Avatar
Originally Posted by landjet
I've had this problem on track, usually when turning and there is a side load on the car. Some think it is from the stock soft motor mounts that allow the motor to shift slightly and affect the cables. Some think it comes from a worn transmission mount. Shifting too fast also seems to contribute to the problem. Henry, i'm surprised that you had this happen with the cup car cables. Only way I have been able to avoid it is by slowing down my 2nd to 3rd gear shift into a diffinite 2 part shift, first to neutral, then into 3rd. You don't need to double clutch but you do have to pause slightly after going into neutral. Hope that helps. My car has the transmission mount upgrade and Wevo motor mounts but will still make a balky shift if I rush it.
Larry, I think my problem was a sloppy adjusted end on the cable itself. I tightened it up and seems to be a-ok now. After messing around down there for quite some time, I'm not surprised at all that the shifts don't line up well. Not of it is very precise... Even with cup cables and 997SSK. Better than stock.. but still.
Old Mar 8, 2012 | 02:41 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Is the green 997 alignment tool what comes with the shifter? I have this odd part that came with my shifter... wasn't sure what it's for. It's clamped on the shift rod itself...
Old Mar 8, 2012 | 09:35 PM
vr4henry's Avatar
As long as it's not installed in your car... yes. You won't be able to move the shifter around with the green thing in place.
Here's a pic
Old Mar 9, 2012 | 08:56 AM
PAULUNM's Avatar
So, do you use the alignment tool to mark the cable on your existing shifter, then use it again when you install the new shifter?
Old Mar 9, 2012 | 08:59 AM
vr4henry's Avatar
Nope. you don't have to mark the old shift levers. But I guess you could just in case you ever had to switch back.
You just clip in the green thing then adjust the cables to where its not pushing/pulling the shifter at rest. It'll make more sense once you're in there. You just don't want to 'preload' the cables in any direction, and the green thing centers the shifter.
Old Mar 9, 2012 | 09:08 AM
PAULUNM's Avatar
Thanks!!
Old Mar 9, 2012 | 09:33 AM
Terminator's Avatar
That sounds like my problem. Have been doing the same shifting practice and all good now. Good to know I am not the only one. Tanx Larry.
Old Mar 9, 2012 | 07:48 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
What ever you do, don't lose that. It locks you shifter in position to set the cables.
Glasgo
Nov 30, 2015 02:37 PM
pwdrhound
11
Nov 25, 2015 01:18 AM
Perkman87
Nov 19, 2015 05:31 PM
vogz
Oct 12, 2015 08:46 AM
