Boost Leaks- how to find them... pics inside
Old Jun 23, 2016 | 12:57 PM
  #301
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
Originally Posted by ghostofpain
Hi Guys,
i did pressure test my car today and i can hear a silent his noise when the pressure gets over 14PSI from the right engine bay side.
Could be fuel pressure line or some line to the change over valve.
What do i need to remove and how to do it? some thoughts? I saw the video from u markski and u fixed the FPR. But u removed some stuff to get there...
Thx in advance
My intake gasket leaked only above 10 psi on the RH side. The leak was bad enough though that it would not create bubbles it just blew the soapy water away from the leak. I could feel it with my hand though. Maybe check that area.
Old Jun 23, 2016 | 02:28 PM
  #302
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Thx. I will remove y-pipe and throttle body. Zip tie every pressure line i can find...and check again. Fingers crossed.
Old Jun 23, 2016 | 02:44 PM
  #303
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
[QUOTE=mikerosi;4531027]
Originally Posted by MARKSKI
Hey Marek, is there a difference between the Kayser DV`s and the Bosch DV`s........I am having a hard time getting the Bosch ones
thanks Mike
They are the same. I had the same question when sourcing parts for my recent (2 weeks ago!) build. My understating is they don't make them under the Bosch name anymore. I just installed some and they were Kayser.
Old Jun 30, 2016 | 08:32 AM
  #304
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Question - What symptoms of a faulty check valve (the two large check valves for example) would you experience? I'm getting surging/bucking and AFRs swinging wildy while under light throttle. TIA!!!
Scot
Old Jun 30, 2016 | 10:10 AM
  #305
Luckily its not a serious leak. Its the famous fuel pressure line.
Its i PITA to get the SAI out of the way.
Old Jun 30, 2016 | 12:58 PM
  #306
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
DAMN that FPR line! I found it disconnected too on my 997. Wire tie EVERYTHING!!
Old Jun 30, 2016 | 02:04 PM
  #307
I Clean the surface of all the lines with brake cleaner to get them fat free. That minimizes the chance that they will slip out again. These little suckers get ziptied for sure.
Old Jun 30, 2016 | 03:10 PM
  #308
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Glad you found it!
Though it's important to understand that this leak posses a more serious threat than most other leaks.
This small leak still allows the motor to build significant boost. And it will run way lean if the tune and setup doesn't have provisions for enough fuel compensation through other means. i.e. Flash tunes that already max out injector duty cycle, now without enough fuel pressure to deliver matching fuel.
Too lean for too long, and kaboom!
Old Jul 1, 2016 | 02:06 PM
  #309
Thats true. Its a dangerous one. Fixed it today and its sealed, but now i can hear a tiny leak around the plenum under the y-pipe.
I feel like the pressure system plays games with me...
Well i will ziptie every pressure line i find now, after i removed the y-pipe and plenum. Jesus next weekend i do some racing. The system must be sealed and hold good damnit..
Old Jul 2, 2016 | 06:58 AM
  #310
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
I repaired my FPR line that had come off and surprisingly did not notice any ANY difference in the way the car ran. I expected to notice something. I am sure i could have seen it from a log, guess my but is not that sensitive.
Old Jul 2, 2016 | 07:03 AM
  #311
BLKMGK's Avatar
FPR would show up in injector duty cycle. So long as you had enough adjustment room in the DME for it to compensate for lack of fuel it wouldn't feel different but injector cycle would be high. Once you ran out of room things could go bad quickly if you didn't notice a CEL!
Old Jul 2, 2016 | 08:22 AM
  #312
That's a big no no. KABOOM usually datalogs, if you know what to log, will show it up.
Old Jul 3, 2016 | 02:25 PM
  #313
One question to the pros.
Is it possible to ziptie the 3 lines comming from the suction pipe left from the plenum? I was told its not, cause there is no room. Any hints or solutions with OEM Plenum...et cetera?
Old Jul 3, 2016 | 02:33 PM
  #314
Of course you can. Whoever told you must not be a wearing white gloves and is scared to get dirty and slightly scratched up. Lol. I've don't it a handful of times.
Old Jul 4, 2016 | 02:05 AM
  #315
Thx alot.
I will test it myself now.
