Change my spark plugs today...
Wow what a difference! I was getting a cylinder number 4 missfire for the past couple of weeks, and a slight bit of a break up on full load in 3rd.
I installed a set of ngk bkr7e's gapped to .026. This was the first time i had instaled plugs on a 996tt or a porsche 6 cylinder for that matter. Although you have to remove a lot of stuff ( wheels bumper intercoolers coil pack covers etc) i found it to be a very straight forward job, As if they engineered it to be done easily.
Once i was ready to button everything up i paid special atention to my upper intercoolers hoses that i had made to go to the speedtech intercoolers. I am certain that i had a boost leak from them earler. I fitted them well and secured the t-bolt clamps down securly.
While i was there i also drain the oil and turbo chargers and gave it a new oil and filter. I also gave it a bath afterwards
All in all the car now preforms as it should its now back to being a BEAST!!
I did my plugs last week, and other than one of the O2 sensors getting in the way when screwing one of the coils back in place I found it to be a "nice" job to do - very well laid out given the space constraints
I don't take off the bumper or the intercoolers. I use a very short 5mm on a 1/4'' flex head ratchet. It just a bit tough to get at the coil harness plugs.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
The only way you can be assured is to do a boost leak test from the turbos... everything else is wishful thinking... OEM cars even have leaks..
2001 996TT 3.6L and stock ECU
They won't clear a stock heigth car in the front. You'll need to use wood to step up and pull onto them or if your garage has a lip at the door put the ramps on the down side and pull on them.
