Timing Chain Tensioner
Old Nov 22, 2011 | 09:04 AM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
How do you loosen the the timing chain? i have already pulled the tensioner cap and spring, but i would have to say it did almost nothing.
Old Nov 22, 2011 | 10:58 AM
Tim941NYC's Avatar
What are you trying to do? If you take the exhaust cam sprocket off you will have all the room in the world.
Old Nov 22, 2011 | 11:01 AM
pumptech's Avatar
Well that crossed my mind but there a lot of tension on the chain still. I'm parting out the motor, so full disassembly. Block is bad, but most everything else is good.
Old Nov 22, 2011 | 11:14 AM
Tim941NYC's Avatar
yup.. take out the bolts on the exhaust and intake cams then walk both sprockets of the cams. the exhaust will come off first then you will have to pull the chain over the the teeth on the intake sprocket to get that one off.
Old Nov 22, 2011 | 11:20 AM
pumptech's Avatar
Then il do it that wAy.
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Well, I have to ask... What happened to the block?
Old Nov 22, 2011 | 12:09 PM
Zmydust's Avatar
Zmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to all
+1 interested as well
Old Nov 22, 2011 | 01:06 PM
pumptech's Avatar
It was in a car that was wrecked. It cracked back where the bell housing would mate. Not my car
Old Nov 22, 2011 | 01:39 PM
Tim941NYC's Avatar
I know where a pair of gt3 sand cast cases are. All those internals will fit in it.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
r_matt_6
Oct 8, 2015 06:07 PM
tkebp1275
Aug 31, 2015 06:35 PM
