Shifted into third and CRUNCH!
Old Dec 1, 2011 | 02:49 PM
  #31
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Matt from GT Gears recommends going back with a straight cut gear - stronger than the stock
https://www.6speedonline.com/forums/...ictures-3.html
Old Dec 1, 2011 | 11:30 PM
  #32
Turbo Fanatic's Avatar
Sorry to hear that man. I think someone else did the same exact thing in the last 6 months? basically engaged clutch with gear half engaged and stripped the whole gear This is an unfortunate fact of life when hurrying a cable operated gear box.
Don't drive the car or drive as little as necessary. The piece floating around in your tranny could and will kill the other gears!
I suggest doing the 997t input shaft? It gives you better gearing (taller) in gears 1-3 a big plus in a modified TT. I know it's a lot, but I would definitely try and do an LSD while I was in there... slippery slope of course.
Good luck and keep us posted!
Of course you can just source a used 9996T, 997T or GT2 tranny and bolt it in?
Old Dec 2, 2011 | 01:35 AM
  #33
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Sorry for hear that! Good luck on your tranny rebuild!
Old Dec 2, 2011 | 09:18 AM
  #34
Dr_jitsu's Avatar
Oh, I have not driven the car since. Going to explore options once we get her out and dissasembled.
My local mechanic is picking her up tomorrow.
Old Dec 5, 2011 | 10:21 AM
  #35
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
Or even just replacing the stock ratio 3rd gear with one of ours. The factory ratio is a 27:38 toothcount, which comes out to a 1.407 decimal ratio. We make the replacement as a 22:31 toothcount, which is a 1.409. What this does is make the tooth larger with a stronger root and shear strength without changing the effective ratio. Obviously, we make a large number of alternative ratios as well, but a lot of people like the stock 3rd gearing and as such we sell a lot of those 1.409 3rd gears.
Old Dec 5, 2011 | 10:45 AM
  #36
2muchtime's Avatar
Rodger from Orbit recently contacted you re; 996tt 3rd gear (my car) so I hope we went with the stronger gear for the extra hp.
Old Dec 5, 2011 | 11:49 AM
  #37
Dr_jitsu's Avatar
Matt,
I have gotten a price from GBox for replacing 1st-3rd gears and replacing the shaft and syncros. If you would like to PM me a price I would be interested.
Sean
Old Dec 5, 2011 | 02:46 PM
  #38
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Hoping it's not too bad for you buddy
Old Dec 5, 2011 | 02:49 PM
  #39
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Huh sorry to hear about this mate. This trully sucks. What bhp are you running?
Old Dec 5, 2011 | 03:13 PM
  #40
ant_8u's Avatar
599hp wasn't it?
Old Dec 5, 2011 | 04:11 PM
  #41
Mikelly's Avatar
Sean, when my box was rebuilt, my indy used Matt for all his parts...
My box upgrade ran me a total of $11300. We converted the hydraulics to GT2, added a guards 40/60 LSD and also had a fresh Clutchmasters disc (fibertuff) installed, along with 997.1 mainshaft, 1/2 with brass syncros, 5th was a PMNA unit, and 3-5 syncros replaced with steel. All bearings replaced, rollpins replaced and safety wired, and all seals replaced. When I sold the car the trans was the last thing I expected to go, but apparently the clutch wasn't setup properly and the clutch fork shifted under a heavy launch by the new owner and he bent the clutch fork and broke the release bearing and pressure plate...
Your's will hopefull not be this expensive, since you aren't doing all that to it... but be prepared. The mainshafts alone can get really pricey and if they need replaced, you have to replace first gear/syncro as first gear is machined as part of the mainshaft.
Mike
Old Dec 5, 2011 | 10:34 PM
  #42
Dr_jitsu's Avatar
Originally Posted by ant_8u
599hp wasn't it?
Lol...
Mike,
I am doing 1-3, shaft and syncros. Gbox is doing it for $6K, which I understand is a pretty good price. Going to leave 4th-6th alone, as they usually don't get broken.
Its 3rd that usually breaks, and you can't upgrade to the stronger 3rd if you don't do 1st-2nd.
Old Dec 5, 2011 | 11:31 PM
  #43
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Are you getting upgraded 1-3s for 6k or OEM? Steel Synchros?
Old Dec 6, 2011 | 12:18 AM
  #44
Terminator's Avatar
Originally Posted by Dr_jitsu
Lol...
Mike,
Lol? He he he so more!
Old Dec 6, 2011 | 04:47 AM
  #45
ant_8u's Avatar
There's a back story
I'll PM you so as not to clutter the thread
