HID lights wont turn on....
Old Dec 1, 2011 | 07:25 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
They worked a few days ago when I drove the car last.. Just started the car backed out and both lights wont go on... I checked ALL the fuses and none of them are blown... I had replaced the ignition switch about 2 years ago and it didn't show any signs of wear or damage before this happened. High beams work, running lights work, signals both work... Any ideas?
Thanks!
- David
Old Dec 1, 2011 | 07:49 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Check the prongs on the back of the headlight. Lots of times they make bad contact and not work.
Or possibly the headlight switch, they sometimes fail as well. But check the headlight prongs first as its free.
Do you know how to remove the headlights? Info inside your owners manual, it's really easy. If not I can help you.
Old Dec 1, 2011 | 07:55 PM
Fire's Avatar
Fire is just really niceFire is just really niceFire is just really niceFire is just really niceFire is just really nice
Highbeams but no low beams...Headlight switch maybe!?
Old Dec 1, 2011 | 10:36 PM
SSMugen's Avatar
So seems like pushing the blinker bar forward to keep the headlights on does not work and neither does the 2nd click when turning on the lights... everything else works as normal.... ugh so annoying... anyone out there know how the light system works?
Thanks in advance!
- David
Old Dec 2, 2011 | 06:56 AM
jpflip's Avatar
Agree with Fire. May be your headlight switch: Look here: https://www.6speedonline.com/forums/...e-replace.html
Old Dec 2, 2011 | 07:43 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
ive replaced two ballasts so far, im just sayin.
Old Dec 2, 2011 | 10:58 PM
hpsyork996's Avatar
hpsyork996 is infamous around these parts
I just had same problem my friend is Porsche tech he said daughter was bad and sure enuff $120 switch fixed it do a switch or find a buddy who will let u swap just to trouble shoot but I bet that's it 01 996 tt is what I have and that's what it was good luck
Old Dec 3, 2011 | 04:31 AM
SSMugen's Avatar
Thanks for the info guys. I ordered a switch earlier for Sunset Porsche for $86. *crossing fingers*
Old Dec 3, 2011 | 08:25 AM
jpflip's Avatar
Agree also with you cuemaster but our friend ssmugen would be a very bad lucky man if both failed at the same time. I also replace one of those litronic control unit and was really surprise of the price of this unit $700.00 !!!!!! (over $900.00 here in Canada ) But found a used one on Ebay for less tan $100.00 !!!!! Look at the circuit board, it was burnt in the lower center....
Old Dec 3, 2011 | 01:37 PM
SSMugen's Avatar
Yikes! hope that isn't the case but i'll update with my findings so we can see how many times these problems are replicated so future members can focus in on the most likely resolution.
- David
Old Dec 6, 2011 | 07:43 PM
SSMugen's Avatar
Thanks for all the input guys. The problem was the headlight switch, quick 10min swap and both lights turned on. Rep for everyone that contributed.
- David
cadman
Nov 13, 2025 08:57 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
