Rear Wiper Deleted - Question
Old Jan 1, 2012 | 08:27 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Just removed my rear wiper
I've trial fitted the plug before sealing it
The plug is 25mm, but the hole in the body panel is nearer 26mm, meaning the plug is able to move around if you put your finger on it
I know I can silicone it in place and all will be fine, but I would have preferred a proper seal to begin with
Has anybody else had a similar experience?
Old Jan 1, 2012 | 10:02 AM
mike5876's Avatar
mike5876 is infamous around these parts
Was it a ***** to get the wiper motor out? I just took off the wiper arm. Gonna do the rest this week
Old Jan 1, 2012 | 10:04 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
It's actually really easy ... I think there are a few
good DIY threads on here. It only took a few minutes ..
Old Jan 1, 2012 | 10:41 AM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
My plug moves around a little bit if I try to move it. I've not bothered tryign to secure it more and it's been fine for over a year now.
Old Jan 1, 2012 | 11:14 AM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Very easy removal, no problem at all to remove the panel that covers the wiper motor. What I did ultimately have a problem with was fitting the rearward facing interior panel back into place (including the thick padding that goes behind it).
Old Jan 1, 2012 | 01:56 PM
pwdrhound's Avatar
You really need to silicone it to get a good water tight seal and prevent any moisture seeping under the plug. Just apply silicone sealant to the plug, press it in the hole, and wipe off the excess silicone that oozes out. Allow it to dry and you are set...
Old Jan 1, 2012 | 03:13 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Interesting thread, however I have a completely different gripe with the rear wiper, I wish Porsche had fitted an intermittent mode and a washer jet as I am constantly pushing the button to get 3 wipes then stop. As you will have gathered , its bloody always raining here and a clear rear screen is essential.
Old Jan 1, 2012 | 03:51 PM
pwdrhound's Avatar
Rain-X should do the trick.....then you won't need the wiper...
Old Jan 1, 2012 | 03:54 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
+1
I used a color matched plug from BumperPlugs....board sponsor I think.
jeff
Old Jan 1, 2012 | 04:06 PM
Good call, hadn't thought about that stuff for years. Might just use some anyway
Old Jan 2, 2012 | 03:47 PM
Wishdiver's Avatar
Wishdiver is infamous around these partsWishdiver is infamous around these parts
I agree with jcb. Bumperplugs is the way to go. The quality of the parts I have received from them has been top notch.
Old Jan 2, 2012 | 05:14 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
bumper plugs worked for me.. at least two years now, and it at least a 5 min job to remove the rear wiper motor very ez
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
TheInfamousDrew
Aug 19, 2015 12:45 PM
