Upgrade from k16/gr2860rs worth it?
Old Feb 11, 2012 | 05:20 PM
johnspeed's Avatar
Originally Posted by PAULIEWALNUTS
Billet 20g's and your PLATINUM.
Please tell us why and do we need more mods for them??
Old Feb 11, 2012 | 05:31 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Yea, Paulie tell us how those 20's are working out for ya!
Old Feb 11, 2012 | 07:30 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
LOL good one Paulie
Old Feb 11, 2012 | 08:17 PM
FlyingGuy's Avatar
FlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant future
So... Are we serious about the billets? Or...?
Old Feb 11, 2012 | 08:37 PM
Blockhed's Avatar
Ice what are your goals? billet 15g's will do 500 on pump gas and 600 on ms109, 20g will do probably 50whp more but it will require a lot more support.
Old Feb 11, 2012 | 09:14 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Originally Posted by FlyingGuy
MY996TT: do you not like the 2871? what is your setup and whats your take on them?
FlyingGuy,
Before I had bigger ICs, Y-pipe, TB and Plenum, I actually felt that those 71s were lack on top; maybe one of the reasons was because I have a Tip. With the bigger piping, the car feels much more alive on top. I don't know your driving habit, but my driving style is some freeway pulls (mostly under 140) and a lot of windy road. Those 71s really fit my style, a lot of low end, good mid-range, and decent high end.
I have a question, my 2871s are ball-bearings; if you convert yours to 71s, will they be ball-bearing?
Old Feb 11, 2012 | 09:22 PM
FlyingGuy's Avatar
I don't really have a HP goal so much. Obviously the higher the number, the better. But I do daily drive my car. I basically want as quick a car as I can without doing rods, having full boost at less than 4k ish. As far as numbers, I'd like to be as close to a 5.99 60-130, and would like to do a 10.99 1/4 mile, AWD if possible. I'd assume I need race gas for these goals, and I'm comfortable with that. I have spoken with Todd K in length about this, and have his suggestions well in mind. I'm just wanting to see what others think. His suggestion is utilize the hardware I have, and cram a 2871 inside. He has seen good results when those are pushed on race gas.
Old Feb 11, 2012 | 09:25 PM
FlyingGuy's Avatar
Originally Posted by MY996TT
FlyingGuy,
I believe that Blouch does a journal bearing 2871 to throw in these early generation A28... I'm still limited by the K16 hot side. Is this the same turbo you have?
Also, any thought on a billet alternative to cram inside here? I guess I could call Blouch about that...
Old Feb 11, 2012 | 10:03 PM
MY996TT's Avatar
Mines are the Garrett ball bearing GT2871s, pre-A28 turbos. I believe the A28 or billet have more potential; but if I have 28s (older) already, I won't even consider them. If you decide to do it, it's not a bad idea to do a dyno before and after; I'm really curious about the numbers. Good Luck.
Old Feb 11, 2012 | 10:08 PM
FlyingGuy's Avatar
I'd like to do a dyno pre and post. But I'd have to drive well out of town, at least an hour and a half. But we will see.
Old Feb 12, 2012 | 05:41 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
When it gets finished I will report.
Old Feb 12, 2012 | 07:06 AM
ttboost's Avatar
Easy grumpy..
Old Feb 12, 2012 | 07:13 AM
Originally Posted by ttboost
easy grumpy..
Old Feb 12, 2012 | 08:10 AM
FlyingGuy's Avatar
not sure what the benchmark is for these itty bitty turbos on 91 octane, but i just ran a 7.39. waiting for Mike to verify!
Old Feb 12, 2012 | 09:29 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
I have K1639's flow 39lbs 1 less than k2418g's
You could see the hot side just starting to choke and temps were just in specification. (A 4" IC would have cured that.)
We could have developed a K16/40+ but decided the hot side would be the problem . Overall these Turbos really really Rock and that's form some one with a full K2420g set up. He recons my car is quicker than his in the mid rev range.
My car was quicker than the factory GT2RS and quicker to 100 than a K2418g car ( testing at Bruntingthorpe Car Testing grounds)
911 Tuning 3 1/2" IC
911 Tuning soft intake
911 tuning tune
60 lb injectors
k&N
Racing dV's
Miltek 100 cell m/sport exhaust.
MKB BOX and TCU
PSS10's all round.
0-60 3 seconds ( have seen 2.8)
0-100 6.5
0-300kph 26.91
0-200 mph 34.17
