Durametric Log / Convert Boost Pressure to BARs
Old Mar 22, 2012 | 05:15 PM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
I drove my car and log it with durametric.
However the value of "Boost pressure of sensor" isnīt in BARs.
How can I convert it to BARs?
The "Boost pressure control deviation" is the difference of pressure between the left and right Turbo? What is the acceptable limit?
Thanks,
Old Mar 22, 2012 | 06:18 PM
WILLIAMP's Avatar
WILLIAMP is infamous around these parts
What unit of measure is it?
Old Mar 22, 2012 | 06:31 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
I believe it's:
subtract 1000 then divide by 1000 and you'll get BAR.
Old Mar 22, 2012 | 06:35 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
14 psi is approximately 1 bar if that helps.
Old Mar 22, 2012 | 11:28 PM
bbywu's Avatar
Are you talking about "Pressure ahead of thr. Plate press. Sensor?"
https://www.6speedonline.com/forums/...ic-primer.html
Boost during WOT is not directly measured. You need to calculate the value based on ambient atmospheric pressure.
"Boost pressure of sensor" is an actual value, and it is displayed in milibars. Ambient pressure needs to be recorded as a constant. Under acceleration, the sensor reading needs to be corrected with the ambient pressure constant.
For example, 990 milibar at idle, means 990 milibar atmostpheric pressure. At WOT (6734 RPM), I record 2178.75 milibar.
2178.75 - 990 =1188.75 milibar = 1.18 BAR
Old Mar 23, 2012 | 01:12 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Old Mar 23, 2012 | 03:46 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
On my Durametric, boost pressure of sensor is reported in mm Hg, not millibars. Updating bbywu's formula:
(Boost pressure of sensor - Boost pressure at idle)/(760 mm Hg/bar) = Actual boost in bar
Jon
Old Mar 23, 2012 | 04:44 PM
vshugo996's Avatar
My durametric software is the last version the boost pressure unit is hPa.
Thanks,
VS
Old Mar 23, 2012 | 05:17 PM
WILLIAMP's Avatar
This is what I always use for conversion.
http://onlineconversion.com/pressure.htm
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
The Oss
Aug 24, 2015 08:19 PM
markski@markskituning
Aug 24, 2015 10:07 AM
