huh? why is this leaking???
Old Mar 27, 2012 | 11:59 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
You don't need to pull the tranny or lower the engine. More than enough space to install the gt2 mod.
Old Mar 28, 2012 | 07:03 AM
Savetheclutch's Avatar
Savetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud of
My biggest issue with doing the Gt2 conversion is sourcing out the parts. I read your thread about the hose and what not.
I can just replace the oem parts for under $500 and do the work myself (with the assistance of my friend and mechanic)
If I could do the Gt2 under 1k i would do it. but at this point I am tired of pissing money away into cars, Not this car but in general I have wasted too much money into this "hobby" lol
Old Mar 28, 2012 | 07:12 AM
sign of failing slave or clutch accumulator or both. this can also lead to power steering pump failure. rather then replacing stock slave and accumulator you are better off doing a GT2 hydraulics conversion. OEM parts you need cost 380 shipped and the custom billet bracket is 200 shipped. so you are at 580 + labor. GT2 hydraulic line wroks just fine, i have been using it for over a year and half.
Parts you need, Pelican Parts is the cheapest for all of them.
Slave Cylinder 99611623790
Master Cyl 99642317106
clutch assist spring 99642308113
hydraulic line 99642337790
DOT4 brake fluid
Billet Bracket for GT2 slave
Optional is the DOT4 cap so down the road a tech doesnt put it Pentosin. I dont have the part # but it is the same part as your brake fluid cap.
#TeamAIM
Old Mar 28, 2012 | 07:37 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Just had my system swapped last month for same issue. Annoying everything felt fine. Went with stock again.
Old Mar 28, 2012 | 07:56 AM
prodigy thank you! who did the work for you?
I might be going down to philly soon, is your car back on the road?
Old Mar 28, 2012 | 07:57 AM
JR @Redline SpeedWorx up in Jersey
#TeamAIM
Old Mar 28, 2012 | 08:04 AM
cool I'll send them a message.
Old Mar 28, 2012 | 08:08 AM
where did you get the bracket?
Old May 3, 2012 | 08:00 AM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
dgreen78 sells brackets...I would like a bracket too but can't PM yet
Old May 3, 2012 | 09:01 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
you can buy the parts on ebay and from dgreen78 on this site the parts are cheapest on ebay (link below) from a parts guy in the us i know because i just bought them PELICAN has run out of the parts
500 will cover all the parts you need for the conversion another 90 will add a braided hose from Torque Solutions or mike at awd motorsports
http://www.ebay.com.au/itm/350555963...#ht_653wt_1139
http://www.ebay.com.au/itm/230759309...#ht_653wt_1139
Old May 3, 2012 | 09:02 AM
timccloud's Avatar
dgreen78 has the bracket and longer slave push rod you need its all very cheap
Old May 3, 2012 | 09:06 AM
timccloud's Avatar
actually 500 will cover the lot with some change as you wont need to ship the parts to australia as i did
Old May 3, 2012 | 11:22 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Agreed. It can be a bit of a pain mounting the slave bracket to the trans blindly, but it's not impossible. Plus if you're using jack stands you can just take a nap when you get tired or frustrated
awesomebang
Jul 5, 2017 08:48 PM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
