PCCB Break thickness question
Old Jul 1, 2012 | 05:41 AM
Sam996TTS's Avatar
Sam996TTS has a spectacular aura aboutSam996TTS has a spectacular aura aboutSam996TTS has a spectacular aura about
Hi, I had my PCCB rotors measured by the dealer and I got the following:
Front Left: 34.21 mm
Front Right: 34.32 mm
Rear Right: 28.23 mm
Rear Left: 28.24 mm
Car has 95k km (~60k miles) and I believe these are the original rotors.
Any idea how much life I still got in them?
Old Jul 1, 2012 | 01:35 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Ask the dealer whats the thickness new and what the minimum acceptable tolerance is. Subtract your current thickness by the thickness when new then divide by the amount of miles. This will give you wear per mile. Then subtract the minimum thickness from the remaining thickness, then divide by the wear per miles. This should give you a rough estimate of what you've got left. At 60K they should be original unless someone really worn the first set out with lots of track time.
Old Jul 2, 2012 | 01:06 PM
pwdrhound's Avatar
Rear Left: 28.24 mm
The Porsche maintenance manual lists the following for the 996 turbo w/ PCCB:
Front brake disk thickness new/minimum limit: 34.0mm/33.5mm
Rear brake disk thickness new/minimum limit: 28.0mm/27.5mm
Old Jul 2, 2012 | 11:43 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Sweet he actually added rotor thickness then!
Old Jul 3, 2012 | 12:01 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Another 60k and they should be at the brand new thickness.
Old Jul 5, 2012 | 12:10 PM
Sam996TTS's Avatar
Yeah these measurements worry me. How come they're thicker than new?! Unless I got some Gen II PCCB's that are thicker than Gen I's or something. I don't know.
And today I saw another Turbo S in the shop. Looked at his PCCB's and they were shiny like a mirror. I was SO JEALOUS.
WaltB
Mar 27, 2026 09:25 AM
J9277655
Dec 28, 2015 11:01 PM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
turbosonoma
Aug 19, 2015 02:05 PM
