Put bigger turbos on...car makes less power
Old Jul 5, 2012 | 07:48 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I recently made a few changes to my car including a new OEM fuel pump, 5" intercoolers and a new EBC. I also swapped my alpha 28 turbos for alpha 3076s. The car is making 20% less power on the dyno and my load is down by ~20%. The logs look good, the boost is stable and the AFRs are spot on.
Anyone have any ideas what could be causing this?
Thanks!
Old Jul 5, 2012 | 08:05 PM
MBailey's Avatar
My guess would be a bum tune. Look at the logs and see how high the timing goes at WOT... Also could be a boost leak.
Old Jul 5, 2012 | 08:18 PM
bad107's Avatar
Tuner said logs look good. We thought intake piping was keeping power down so this is on a mafless tune with filters on the turbo for the dyno.
Old Jul 5, 2012 | 08:45 PM
Tim941NYC's Avatar
what is your boost psi now and before with the 28's
Old Jul 5, 2012 | 09:02 PM
bad107's Avatar
i am just doing 1 and 1.3 bar pulls
Old Jul 5, 2012 | 09:17 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Do you have a fault code(air mass)in the DME memory since you are running mafless tune?
Old Jul 6, 2012 | 12:57 AM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
Was the car retuned after all these new mods?
Old Jul 6, 2012 | 02:25 AM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
Gotta be something wrong. Keep looking. I'm sure you'll figure it out and make lots of power.
Good luck!
Old Jul 6, 2012 | 06:15 AM
Tim941NYC's Avatar
Are you overlaying 1bar and 1.3bar dyno sheets?
Old Jul 6, 2012 | 09:43 AM
bad107's Avatar
tim, those charts are sent you have the before and after mafless overlayed
neil, i have a bosch 044 booster pump and the afrs look good
Old Jul 6, 2012 | 10:46 AM
XLR82XS's Avatar
That's my thought - boost leak.
Old Jul 6, 2012 | 01:11 PM
bad107's Avatar
The boost is coming on and holding stable though...
Here is a dyno and log
File Type: pdf
Old Jul 6, 2012 | 01:16 PM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Could it be the Dyno itself
Old Jul 6, 2012 | 01:17 PM
bad107's Avatar
here is a log from before I swapped my turbos, intercoolers, fuel pump and headers and not on the mafless tune
File Type: pdf
Old Jul 6, 2012 | 01:53 PM
boost looks like its coming on super slow which could be a by product of a boost controller. your peak tq is 530 at 4300rpm, when i ran those on pump/meth at 1.5bar i was getting 530 at 4000rpm and 590tq peak having the gates crack at 13psi.
i would check the wastegates too and your boost control, maybe try running N75 for boost control.
#TeamAIM
