Deionized wash system
Guys this is not an endorsement and I have no affiliation with CRSpotless. My turbo is black and you all know what that means. I bought a deionized wash system from www.crspotless.com based on their money back guarentee. The system worked exactly as promised. I won't be sending mine back! I used the filtered water to fill the soap bucket and rinse the car. Then I pulled it in the garage and then went out for the night. We took the wife's ride. The outside temp was about 68 degrees with a slight over cast. It was about two hours before sunset when I washed it. Anyway the next morning I pulled the car out and damn if there wasn't a single spot on the car. I was blown away. Do your own research but as an owner of a black car I'm always looking for anything that helps me keep it clean and I thought I'd share my experience with my fellow 6speeders. Richard
After the rain we've had, that makes me think you could rinse the car before pulling it in for the night just to keep all the road grime from adhering to the paint.
BTW, did you run in the PCA autocross today?
Re: Deionized wash system
Re: Re: Deionized wash system
Originally posted by Vik
The Mr.Clean Autodry works exactly the same, but for MUCH cheaper. The kit is only $30 and the refills are $6-$9.
the Mr Clean seems to work and appears the same concept as the one posted, but I still have to wonder how safe it is on your paint long term. These types of washes have only been on the market recently and Im not so sure they wont have any ill effects on the wax/polish job or on the paint itself. Does anyone know for sure?
Originally posted by Ferrarislave
It is is just water, just 100% pure water. The water spots you get are from the minerals left over after the water evaporates. They are 100% safe on your paint and will not remove any type of wax or anything else.
You still have to wash the car, you just don't need to dry it. I heard you spend a lot of time and water rinsing. Plus, you have to use their soap.
Speaking of car wash, I got a sample of "bucket less car wash" from eagle one. You spray onto rinsed car and wash with a mitt but no bucket. I'll have to test it to see if it saves time.
I have used DI (De-Ionized) water a few times on the car, never a spot. As said before the spots are from the minerals in the water that get left behind after drying. DI water is better for your paint (although probly no real difference) because there are no ions (minerals) in the water. Just in case someone is wonderinf DI has a resistivity of 18 M-ohm / cm.
When i wash with DI, I wash normally with tap water, rinse with tap, then rinse with DI. (mainly cause I dont have a DI tap at my house. I fill up jugs of DI from the lab I work in then take those home to rinse with)
DI water is also much better to use in your radiator then tap(no impurities to cause fouling).
Thanks, your sharing just taught me about deionized water. I have been using spot free water filter & softner for about a month now and I really like it a lot, but I've been drying my car right away using a powerful electric leaf blower.
I wash the wheels last and then blow dry them as well.
Regards,
Craig
Regards,
Craig
