What'll it cost me?
Old Dec 5, 2012 | 07:25 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
What'll it cost me?
Gang - what should I expect to pay for the following items at an indy shop?
Swapping out my stock shifter for a 997 one (Already have part)
Replacing the oil pressure sender unit (With new part)
I know shop labor rates vary, so how much time am I looking at for these? I have 10 thumbs and zero ability, so DIY isn't an option.
Just curious so I know going in and I can plan accordingly. I like the shop I use but I operate under the "trust, but verify" rule.
Thanks!
Todd
Old Dec 5, 2012 | 07:27 PM
32krazy!'s Avatar
the shifter takes less than 2 hrs total. its really very easy to do. watch the numeric dit=y video on their f/b page
Old Dec 6, 2012 | 04:32 PM
leftlane's Avatar
Thanks 32 but whenever I try anything, I have to pay a pro to fix my mistake and then do the job right. I know my limitations and am not afraid to admit it.
Old Dec 6, 2012 | 04:48 PM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
Too bad you're not close. I would do both of those for $200.
Old Dec 7, 2012 | 07:49 AM
XLR82XS's Avatar
That's good you admit that. I have seen my share of inferior work and repair attempts at my facility. Always great to have a local indy that is experienced, knowledgable and trustworthy.
Old Dec 19, 2012 | 06:53 PM
leftlane's Avatar
My shop has quoted 1.5 hours for the shifter install and 2.5 hours to replace the oil pressure sender plus $58 for the part, for a total of $551. Seem reasonable? Wish I knew how to do this stuff myself - it would make Porsche ownership a lot more manageable.
Old Dec 19, 2012 | 07:55 PM
32krazy!'s Avatar
honestly the shifter install is one of the easiest mods you can do for a novice. it takes more time to remove the center console than anything else. its a great way to start learning about your car. take your time and do the research before you start.
Old Dec 19, 2012 | 08:15 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
I just paid the dealership $200 plus tax in labor to have a 997 ss installed.
Old Dec 20, 2012 | 05:38 AM
'02996ttx50's Avatar
my tech switched out my stock shifter for the 997 ssk. it took like 20 minutes and was done in my driveway.
Old Dec 20, 2012 | 06:26 AM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
The correct answer is "How much money do you have"?
Probably between $500-$600 to farm it all out.
Old Dec 20, 2012 | 08:59 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Most of the time in the shifter install is just R/R the center consol. It really is a easy DYI. While your at it you can get a factory CF shifter lever and E Brake handle (Suncoast).
Old Dec 21, 2012 | 08:01 AM
XLR82XS's Avatar
Good advice - I did that. Both CF parts are a really nice touch.
Old Dec 21, 2012 | 08:33 AM
leftlane's Avatar
Already have both of those pieces. Plus - I'm looking to spend less, not more.
Seems swapping out the entire shifter would require some skill to not fudge it all up. I'm looking for smooth - not mangled, as it would probably be if I did it.
I was actually more surprised that the oil pressure sender is a 2.5 hour job. I thought that would be really quick based on what I've read on here with guys swapping them out in 10 minutes on their own.
Old Dec 21, 2012 | 11:49 AM
32krazy!'s Avatar
the hardest part about replacing the shifter is getting the shift **** off. thought it was going to fly out of the sunroof when it turned loose!! other than that its about 20 or so bolts screws and clips. its a 2 on a scale of 10
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
jonate24
Oct 25, 2015 11:34 AM
docboy
Sep 27, 2015 07:29 PM
