where is the AC comp electrical plug?
Old Mar 23, 2013 | 01:48 AM
mikes996turbo's Avatar
mikes996turbo is just really nicemikes996turbo is just really nicemikes996turbo is just really nicemikes996turbo is just really nicemikes996turbo is just really nice
Hi learned folks, my AC stopped working recently and I found the compressor clutch not pulling in, I could make it work by supplying 12v, so I have pulled the compressor off and found the small spade terminal was not connected at the other end.
Question where does it plug into, I have search and cant find the other end....please give me some pointers, feeling dumb here found the problem cant fix it!!
thanks
mike
Old Mar 23, 2013 | 05:46 AM
jpflip's Avatar
There is only one wire going to the compressor which is green and yellow and goes to main plug X59/1 (25 pins) in the engine compartment right side.
Low pressure or lost of refrigerant can also cause the compressor to stop working. Even if you bypass the relay a low pressure condition will cause the compressor to stop working.
If you look at the picture you will found the connector for the compressor wire. This connector is located on the right side of the engine over the coolant pipe connection. The last picture is with the engine in place but you can barely see the connector.
Name:	Capture d’écran 2013-03-23 à 07.51.01.jpeg
ID:	223529   Click image for larger version
Name:	Capture d’écran 2013-03-23 à 07.56.43.jpeg
ID:	223530   Click image for larger version
Name:	Capture d’écran 2013-03-23 à 08.02.41.jpeg
Old Mar 23, 2013 | 04:19 PM
amazing help - many thanks jfilip
Old Mar 23, 2013 | 04:44 PM
jpflip's Avatar
Welcome Mike. Hope you will resolve your problem.
Old Mar 24, 2013 | 01:35 AM
All fixed and blowing nice and cold......thanks
BLKMGK
May 31, 2016 04:32 AM
jungt
Sep 16, 2015 05:28 AM
johnny.dangerous
Sep 14, 2015 02:19 AM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
flewis763
Sep 10, 2015 01:08 PM
