Upgrade tiptronic for more HP
Old Apr 4, 2013 | 05:17 PM
911turborookie's Avatar
911turborookie is infamous around these parts
So as every tiptronic owner we reach a plateau with Hp so we don't have failure with our transmission This is where I fall - so I would like to know has anyone upgraded there tiptronic/transmission so they can achieve more hp without worrying about it failing??? Is there anywhere in NY that does this?
Thanks in advance!
Old Apr 4, 2013 | 07:10 PM
No one upgraded there transmission to accommodate more hp ?
Old Apr 4, 2013 | 07:34 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Hey bud, do a search. There are some companies that offer this service. Do your research and make a choice.
Old Apr 4, 2013 | 07:39 PM
Recommendations?
Old Apr 4, 2013 | 07:51 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
How much real power are you making. I think around 550-600 crank is at the limit. Maybe 600 if driven prudently. Eventually it will need attention at higher power levels. Do a search as there are exhaustive posts about upgrading the tip. From what I have read maybe 3-4 places discussed with cost around 4-6k not including deinstall and reinstall of your tranny. One place that rebuilds (texas shop?) does these rebuilds and I bet you could drive or ship your car to them and let them rebuild and reinstall. Seems like machining gearbox to accept more clutches and adding some cooling to fluid and upgrading valve body for quicker shifting are the main upgrades. Some of these rebuilds will have you good for nealy 900 or so ft lbs. Do it right so you can run as much power as you care to pay for! This way 700-800 hp will be no prob. and that is plenty fast in a street car! Good luck.
Old Apr 5, 2013 | 02:26 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I built my tiptronic by ESMOTOR ,
Since 2 years and no issues , 800awhp
Old Apr 5, 2013 | 03:08 AM
How did you get your trans to them?
Old Apr 5, 2013 | 03:31 AM
ysfg35's Avatar
Contact emre , he is a vender here !!
He will give u better answers
Old Apr 5, 2013 | 08:02 AM
MBH's Avatar
MBH
MBH has a spectacular aura aboutMBH has a spectacular aura about
Here is a good thread - linked to a good post regarding a few different places that can service them. If I'm remembering this correctly Renntech is the least expensive option, and they've earned a good reputation as far as I know. Emre does a LOT for the money, and I think he even revalves the transmissions to shift a lot faster - but he's overseas so it might not be the most practical. I have no experience with any (and hope that I don't have to haha)
https://www.6speedonline.com/forums/...ml#post3257495
Old Apr 5, 2013 | 06:06 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
https://www.6speedonline.com/forums/...1-pd-code.html
This is not finished.. I have more to post on this but along the way I collected a bunch of info and other posts.
Old Apr 5, 2013 | 06:52 PM
32krazy!'s Avatar
isnt the tiptronic a mercedes trans? if it is then southern hot rod or paramount performance have trans upgrades for under 6000$
Old Apr 5, 2013 | 07:04 PM
pat's Avatar
pat
Yes it is .. It's a 722.6 this is used in many cars. The valve body and guts are the same in many applications. Different ratios and castings but basically the same.
Old Apr 5, 2013 | 07:06 PM
32krazy!'s Avatar
bothy of the above companies have been building high hp trans for the mopar cars for yrs. they use the same trans as the benz. high hp torque convertors also
Old Apr 5, 2013 | 07:11 PM
pat's Avatar
pat
http://www.scribd.com/doc/37436253/722-6
Here is the tec info for that trans.
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
Weebs
Sep 7, 2015 11:42 AM
faiz
Sep 2, 2015 08:43 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
