Misfires, Error Codes, Etc..
Old Apr 6, 2013 | 10:39 PM
tvieso's Avatar
tvieso has a spectacular aura abouttvieso has a spectacular aura about
Originally Posted by MARKSKI@911tuning
get these plugs dont gap them just put them in...
Denso 3245 PK20PR-P8 Double Platinum Spark Plug
Item# DEN3245
on dash it says how much boost ... you should see .7 bar...
Okay, thanks. But before I tear my car apart again, why are these plugs so much better?
Also, saw 1.0 bar tonight fairly easy on an empty street. Wasn't even WOT. That normal? Could my car have a tune?
Old Apr 7, 2013 | 10:16 PM
tvieso's Avatar
Update. I disconnected the battery to disassemble the headlight switch tonight to diagnose a "fog light constantly on" problem and after that the car now is misfiring badly, even at 1-2K rpm. It didn't do this before. I'm lost.
I did, however, observe that the boost pressure was ALL OVER THE PLACE. During WOT, car was misfiring/sputtering while I watched the boost pressure jump from .4 to .8 to .5 to .2 and so on.
HELP?
Old Apr 8, 2013 | 06:47 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Make sure a control hose didn't come off a diverter valve.
Old Apr 8, 2013 | 09:27 PM
tvieso's Avatar
Just hit 1.4 bar today. So...definitely not stock. I don't know who tuned it, but I guess next step is to look at the DME and then get it reflashed to stock?
I've attached a few videos I took this morning of a cold start, idle and the 1.4 bar run.
And just to reiterate, the dealer did a smoke test, vacuum test, tested the MAF and cleaned just for good measure, looked at DV's, checked out injectors (one of which was questionable he said)...and everything was good.
I'm not sure what other upgrades the car has on it, but is it considered "unsafe" to be running that much boost pressure without other upgrades like 5.0 bar FPR or bigger injectors?
Thanks for any input.
Travis
Old Apr 9, 2013 | 07:20 PM
pat's Avatar
pat
My boost was all over the place like that when the DV control hose was off.
Old Apr 9, 2013 | 07:38 PM
could be loose hoses off the N75 etc etc...
he needs a pressure test to start... then continue...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 10, 2013 | 12:36 AM
tvieso's Avatar
Copy that. Thanks, gentlemen. I'll try to find some time this week to work on her.
Old Oct 2, 2013 | 06:05 PM
trbo4wd's Avatar
trbo4wd is a jewel in the roughtrbo4wd is a jewel in the roughtrbo4wd is a jewel in the roughtrbo4wd is a jewel in the rough
When I scroll through these post, I am always curious if a problem was found and what was the resolution?
Old Oct 2, 2013 | 06:56 PM
tvieso's Avatar
Problem was never found. I ended up trading it in for a lease with a different manufacturer. I didn't have the time, space or money to work on it myself. I had changed out the coilpacks and spark plugs at the time. I wasn't about to give the dealer any more of my money either after I realized the techs didn't know much more than I do.
I will most likely get another Porsche at some point because they are so fun to drive as well as being pretty practical for a high-end sports coupe, but I will make sure there is plenty of warranty remaining.
Old Oct 7, 2013 | 03:32 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
That's really too bad. I too was reading through and hoping for a better ending.
Old Oct 7, 2013 | 10:34 AM
Macster's Avatar
Hardly the techs' fault that some goofy tune was in place. I'm surprised you didn't flash the thing back to stock and then trouble shoot from there.
longboarder
Sep 21, 2015 12:57 PM
Boltons991qtr
Sep 20, 2015 06:57 PM
intouch1
Sep 20, 2015 06:14 AM
nick-seattle
Sep 18, 2015 08:14 AM
