Who sells fuel injector spacers?
Old Apr 25, 2013 | 10:40 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Looking for some spacers for the Siemens 60 pound injectors. Who has them?
Old Apr 25, 2013 | 10:46 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Call Markski at 911tuning. He has em
Old Apr 25, 2013 | 01:16 PM
Tim941NYC's Avatar
Why use that injector? There are better injectors available.
Old Apr 25, 2013 | 01:32 PM
raineycd's Avatar
Old Apr 25, 2013 | 03:48 PM
brnrdtns's Avatar
I got them thinking they were what I needed? Should I switch or am I ok?
Old Apr 25, 2013 | 04:26 PM
johnspeed's Avatar
I didnt think the 60s needed them ,,only the 72s ?
Old Apr 25, 2013 | 04:42 PM
32krazy!'s Avatar
i have the 72 lb injectors. no spacer needed
Old Apr 25, 2013 | 05:45 PM
johnspeed's Avatar
I believe when I got my 72 injectors from EPL way back when, there were some kind of spacers,,Maybe for the fuel rails now that I think more about it because of the height of those injectors..
Old Apr 25, 2013 | 05:49 PM
32krazy!'s Avatar
no spacers at all on mine. got them from epl also. i did open the mount holes in the rail just slightly with a file but that was it. plug and play with the adapters for the connectors.
Old Apr 25, 2013 | 06:07 PM
Tim941NYC's Avatar
Those injector have been around for quite so time.. Why they where used?
1) They where the largest high impedance injector available.
2) They use the EV1 plug.
The reason people use them is there is plenty of drop in flashes available. You can only make about 775-800 rear wheel with those injectors running high rail psi and no over head left (100% duty). It is safer to run a bigger injector as the ecu will trim 25% +/- to save you engine if need be. There are plenty of high impedance injectors out there to choose from, many need no mods to the rails.
Tim
Old Apr 25, 2013 | 06:49 PM
brnrdtns's Avatar
I'm not running more than 600 at the wheels on my 18g setup so I think they will be fine.
Old Apr 25, 2013 | 07:27 PM
we use 60s and 80s.. work very well... had only one fail at startup but the shop caught it....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 2, 2013 | 09:49 PM
brnrdtns's Avatar
Looks good, thanks Markski! I'll see how they fit over the weekend.
L.A.P.
Oct 19, 2015 10:01 PM
orbelo
Aug 30, 2015 12:26 PM
Just Cruise
Aug 25, 2015 12:39 PM
Mar48
Aug 24, 2015 01:13 PM
L.A.P.
Aug 23, 2015 11:48 PM
