996 Door Latch
Old Jun 2, 2013 | 08:22 PM
Y3LO 01's Avatar
Y3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud of
996 Door Latch
When I open the driver side door, either by using the outer or inside handle, the window drops down about an 1/8" like it is supposed to but the window immediately rises back up even when the door is open.
I assume the microswitch in the door has failed but my understanding is you can't buy the switch by itself. You have to buy the entire door latch. Does anyone have the OEM part number for the drivers door? I've done several searches and have looked through the shop manual but no luck.
Thanks.
Old Jun 2, 2013 | 08:33 PM
raineycd's Avatar
Have you tried to re-train the window? Basically move it all the way down, hold button 10 seconds, move it all the way up and hold for 10 seconds I believe.
I had to have mine replaced. I'll dig up the work order for the part # as well.
Old Jun 2, 2013 | 08:53 PM
Y3LO 01's Avatar
Yeah I tried the reset trick with no luck. I appreciate the help on the part number.
Old Jun 2, 2013 | 09:16 PM
raineycd's Avatar
Ok looks like the part number on the work order is 8N1837015C for drivers side door lock assembly.
Old Jun 2, 2013 | 09:24 PM
Y3LO 01's Avatar
Fantastic! Thanks for the help.
Old Jun 2, 2013 | 09:40 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
I just replaced my door lock mechanism for the same thing last week. It's a pretty straight forward fix.
Old Jun 2, 2013 | 10:49 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
That is an Audi or VW number. Try those dealerships before going to a P car dealer. Maybe less $$$.
Old Jun 3, 2013 | 06:44 AM
'02996ttx50's Avatar
i replaced mine with one from a dead boxter. it's another 986/996 part.
Old Jun 3, 2013 | 10:54 AM
32krazy!'s Avatar
i replaced the microswitch on my door and it didnt fix it. i then bought a used latch assy and it fixed the issue but then the door wouldnt lock. bought a new assy and it fixed everything. by the time i was done dinking around i spent more than a new latch would have cost.
just saying
Old Jun 4, 2013 | 10:51 AM
XLR82XS's Avatar
Similar issue 1.5 years ago. Replaced the latch assembly and all is good again. Microswitch did NOT fix the issue.
Old Jun 8, 2013 | 08:22 PM
Y3LO 01's Avatar
I replaced the latch today and it fixed the problem. The install was a bit harder than I anticipated but it's done and works great.
However, upon startup of the car my airbag warning light came on after about a minute. I had to take out the side air bag to replace the latch so presumably I disturbed something in the side air bag. I put the connector back on but the small purple weather jacket that is on the connector broke off. However the connector still connects fine. Could this cause the issue? I doubt it but not sure what else it could be. Any thoughts?
Old Jun 8, 2013 | 08:39 PM
rmc1148's Avatar
The battery should be disconnected for a while before fooling with the bags and you should touch to ground to discharge static electricity.
Old Jun 8, 2013 | 08:59 PM
rmc1148's Avatar
When I say touch to ground to discharge electrical static to clarify I'm talking about your physical body= hand etc.
Old Jun 8, 2013 | 09:49 PM
code7rpd's Avatar
I didn't remove the airbag for mine, but did loosen one of the bolts holding the airbag to the metal brace behind the door panel for proper access. The brace has to be removed. Once you disconnect an airbag, the only way to reset it is via the dealer scanner - not sure if a Durametric works for airbag lights or not. You can try to disconnect the battery to see if it helps clear the code.
Old Apr 16, 2014 | 01:09 PM
deptotpr's Avatar
deptotpr is infamous around these parts
Well it was worth the try; however, did not work. Setting an appointment to the dealership. :/
