My Differences in Dyno Numbers
Old Jun 3, 2013 | 12:59 PM
johnspeed's Avatar
Hey Guys I am at Fluid MotorUnion doing the exhaust swap comparison now. My 100cell Milltek to a Fabspeed catless X.
All I can say it that their Dyno Dynamite dyno in a 4th gear pull is not a happy numbers dyno as compared to the others I have been on. They don't use 3rd because they say it is to violent for the strapping situation.
Ok,, on Protomotive rear Dyno Packs-625, Porsche Exchange rear Dyno Jet-600, Kelly Moss AWD Mustang - 550, And now on this Dyno Dynamics so far 515 before swap.
The graph power curves looked all pretty similar on all the dyno's.
Truth be told.
Old Jun 3, 2013 | 01:31 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
It is 3:30 now, what are the numbers with your new exhaust already!
Old Jun 3, 2013 | 01:34 PM
johnspeed's Avatar
LOL... It's only 2:30...LOL
Old Jun 3, 2013 | 01:41 PM
Bobbyfali's Avatar
Sorry I forgot it is a time difference in Toronto Canada.....
Old Jun 3, 2013 | 02:00 PM
johnspeed's Avatar
Doing it now as we speak..
That Fabspeed exhaust is done very nicely, as the cat delete pipes are opened/blended to match bigger tubos also..
Old Jun 3, 2013 | 02:17 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
You're running in 4th and getting a low number.. that's the closes to 1:1 in our cars.
1st 3.82:1
2nd 2.05:1
3rd 1.41:1
4th 1.12:1
5th 0.92:1
6th 0.75:1
Typically dynos give different reading in different gears. If I remember right, 3rd should give a lower number.. I don't know anything about Dyno Dynamics. My buddy has a Mustang and DynoJet so that's all im used to. Should just goto a DynoJet and spin the 1000lbs roller..
Old Jun 3, 2013 | 02:26 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
1st 3.82:1
2nd 2.05:1
3rd 1.41:1
4th 1.12:1
5th 0.92:1
6th 0.75:1
Actually, 5th is closer.
Old Jun 3, 2013 | 02:29 PM
Your Mustang dyno numbers are actually pretty good versus the Dyno Jet numbers. I have seen several people have a variance closer to 15%.
Not sure about the Dyno Dynamics numbers.
I have also seen newer Dyno Jet numbers that were comparible low to Mustang dynos.
Later, Steve
Old Jun 3, 2013 | 02:36 PM
johnspeed's Avatar
Later, Steve
But what type of Dyno Jet,, rear wheel only like I was on Or an AWD one, most likely a AWD one..
Old Jun 3, 2013 | 02:38 PM
johnspeed's Avatar
Did a few 5 th gear pulls in the past and made less HP,, probably do to heat soak with the longer time for the pull.
Old Jun 3, 2013 | 03:26 PM
King James's Avatar
By numbers yes, but don't want to go over (under) 1:1. It's like Price as right, as close as you can without going over
Old Jun 3, 2013 | 03:30 PM
johnspeed's Avatar
Plemimary report,, catless X makes more down low and more TQ But 100cell Milltek makes more in HP in Upper Mid and the same at high RPMs.
Old Jun 3, 2013 | 03:32 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Are you running the Fabspeed 2.75" X-Pipe?
What do you think of the sound? Any drone?
Old Jun 3, 2013 | 03:36 PM
johnspeed's Avatar
Yes that's the one, catless.
?? Still on dyno.
Old Jun 3, 2013 | 04:42 PM
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
John, as I said in the past, Dyno dynamics always read low. They are an Aussie made heartbreaker!
