V noisy LWFW
Old Aug 26, 2013 | 05:55 AM
  #31
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
normal, completely normal. 10x worse on my e46 m3 and everything is in front of you...
Old Aug 26, 2013 | 09:24 AM
  #32
johnspeed's Avatar
Wouldn't a heavier steel one be quieter then a aluminum one ??
Old Aug 26, 2013 | 10:10 AM
  #33
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
I think being single mass is the problem. The dual mass balances out the vibration. I think a steel one may reduce the noise a little but will always be noisy......not even sure if one is even made for our cars .......can't be that much savings in weight compared
OE Dual Mass : 32.8 lbs (from pelican parts)
LWFW : 14.5 lbs (from pelican parts)
I don't see a single mass steel wheel any where listed.
Old Aug 26, 2013 | 10:18 AM
  #34
johnspeed's Avatar
I believe it is a Porches RS factory one,, also I think Sambo sells one and Kevin from UMW uses that in his kits because they are quieter?
Old Aug 26, 2013 | 09:14 PM
  #35
Daytonaman's Avatar
Daytonaman has a spectacular aura aboutDaytonaman has a spectacular aura aboutDaytonaman has a spectacular aura about
Not knowing the design of the ring/flex gear on a TIP, would the mass on a TIP input shaft be more or les than a LWFW? This would include the TC and the rotating components. My TIP rattles..
Bobbyfali
Jul 31, 2017 01:28 AM
rob4wellness
Oct 2, 2015 07:32 AM
oo7
Sep 10, 2015 08:08 AM
steve.rinaldi
Sep 5, 2015 06:52 AM
