Pretty sure I just blew my motor...
Old Oct 31, 2013 | 12:38 PM
  #76
Originally Posted by brnrdtns
Looking at the piston through the spark plug hole, and it looks to be in tact. Could I have gone lean fuel in one cyl, had that cyl seize, and disconnect the rod from there? My fuel system is stock with 60lb injectors, running 1.4 bar on 95 octane. Is that enough fuel?
1.4 is a lot of boost for 5th and 6th gear loads on pump fuel.
when i ran 1.55bar on stock motor i never ever did 5th gear pulls and my motor stayed together. gotta reinforce some stuff to push big power in 5th and 6th. yeah piston most likely will not show any damage on top in this situating since the rod caused the failure, on sides it will have some damage.
#TeamAIM
Old Oct 31, 2013 | 03:00 PM
  #77
WOODTSTER's Avatar
I did zillions of full 5th gear pulls at 1.4 bar on Stock motor. second fuel pump, larger modded fuel rails, K24-18g's with a variety of fuels. On pump fuel I would only run 1.0-1.1 bar.
Old Oct 31, 2013 | 04:31 PM
  #78
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
zillions?? sounds a little unrealistic
Old Oct 31, 2013 | 04:43 PM
  #79
ttboost's Avatar
Yeah Marty..we all know it was only millions!!!!
Old Nov 1, 2013 | 07:33 AM
  #80
im not saying people should or shouldn't do 5th gear pulls lol. I didnt because my car was making way more power then a 18G car and i wanted to last. high load and high boost will break stock rods, fact.
#TeamAIM
Old Nov 1, 2013 | 08:49 AM
  #81
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
The plug on the blown cyl is peppered, or the carbon deposits on the plug are chipped while the other plugs are normal.
Old Nov 1, 2013 | 08:51 AM
  #82
brnrdtns's Avatar
The piston is deep inside the cyl away from the head and seems seized.
Old Nov 1, 2013 | 10:33 AM
  #83
pumptech's Avatar
If that's the case and the engine still turns, the rod must be obliterated and in small enough pieces that its not jamming things up.
Old Nov 1, 2013 | 10:07 PM
  #84
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Im hoping you get it fixed and your block is saved.....
therock88
Jul 14, 2018 11:22 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
speedsterr
Oct 26, 2015 09:18 AM
007 Vantage
Oct 8, 2015 08:35 PM
