Best Way to top the Oil Off?
SubscribeThe oil is at the bottom bar.
So I was going to get the car to the operating temperature, turn the car off , pour in a 1/4 of a quart and turn on the car and take a new reading.
Anyone know the amount of oil it usually takes when its on the bottom line? Also can I keep the car running the whole time?
Anyone? I am about to do it myself in about 30 minutes….
Just need to know if its ok to have the car running when doing the top off and taking readings or just off and at operating temps?
Quote:
i could be wrong but i would be willing to be it takes more than 1/4 qt
No, I was going to put in a 1/4 quart then take a reading, another 1/4 quart, another reading……etcOriginally Posted by XwalkerX
IIRC 1qt=4barsi could be wrong but i would be willing to be it takes more than 1/4 qt
I bought 2 quarts…..
sounds like its a qt low. i would add at least 1/2 qt at op temp and check it again, add as needed. while running is fine. iirc? each line represents 1/5 qt on the gauge.
lol. 1/4 or 1/5.. either way you're at least 3/4 qt low
I typically fill mine to 1/2 to 3/4 from full (top bar). In my mind, it helps lessen the occasional smoke at startup. I let the oil go down as low as the bottom bar then back up to about half.
you can do it with the car on or off, cold or hot, doesnt matter (you already have your reading). add the entire quart, you wont be topped off with a quart, you'll be where you need to be. (1 bar remaining = its full)
Took about a quart and a third…….to one line before full.
if it were me? i'd be a bit more mindful of the level moving forward. i used to check mine at every long stoplight lol. thankfully, i've let that obsession go.
Quote:
I used to keep mine full and had smoke at startup. Now that I keep it about half I dont have that issue anymore.Originally Posted by thomapa1
- 2009 GTR-FBO-E85-70k Miles-NJ-Cheap
- 80k mile report V8V
- :: ECS Tuning :: Premium Oil Service Kits for your VW MK6 Jetta GLI - Click Here !!!
- :: ECS Tuning :: Assembled by ECS Oil Service Kits|VW Gen3 1.8T/2.0T - Click Here !!!
- :: ECS Tuning :: Premium Oil Service Kits for your VW MK5 Jetta 2.0T - Click Here !!!
