TRG front / Tarett rear drop link pics
Old Dec 7, 2013 | 01:51 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Just getting mentally prepared to install my shinny new TRG front and Tarett rear adjustable drop links. Looking for inspiration ..
Anyone have any pictures of these drop links installed?
Old Dec 7, 2013 | 06:52 PM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
Here is a picture of one of my front drop links. It is hard to tell from the instructions which way they should be attached. I actually installed them oriented differently but they were rubbing a bit, so I went this this. I also took one of the three washers off the bolts to get the right clearance. I assumed they were there for playing with the spacing and clearance. Car actually felt noticeably better as soon as I put these on. I must have had some pre-load on my sway bars before. FYI, I'm lowered on PSS10.
Old Dec 8, 2013 | 02:24 PM
TurboTodd's Avatar
Just installed the Tarett rears. Super easy, now its on to TRG fronts
If anyone has pics of their TRG fronts to share that would be cool.
ID:	309307   Click image for larger version
ID:	309308   Click image for larger version
Old Dec 9, 2013 | 01:30 PM
pwdrhound's Avatar
The front Tarett extended drop links are the way to go. They provide much better geometry compared to a shorter drop link due to their +6" higher attachment point.
ID:	309735   Click image for larger version
Old Dec 9, 2013 | 02:18 PM
TurboTodd's Avatar
Yep I have seen pictures of your beautiful set up before. I do like the higher attachment point as well. In fact the KW V3s I am using have an extended link like that but in a stock like non adjustable form. The Tarett guys are great, they said they would make me an extended adjustable link to replace the KW.
If I didnt get such a great deal on the TRGs I would have had the tarett guys make me one up. I have the TRGs now and going to use em.
It doesnt seem like anyone has a picture of the TRGs installed. No biggie it looks super simple. I will post when I have them in.
Old Dec 9, 2013 | 02:31 PM
pwdrhound's Avatar
Whatever you use make use you install the dust boots on all the heim joints. They completely seal out all dust and moisture and keep the joints looking like new. I've had the seals on my drop links for the past 2 years and the joints are spotless last time I checked them.
Old Dec 9, 2013 | 02:39 PM
TurboTodd's Avatar
Two schools of thought on the boots. Some say they may cause more harm than good by trapping the the dirt and moisture in. Most dont inspect their components so the wear goes undetected.
For me I am under the car all the time. I know I am obsessive but clean them every time I drive the car. No problems in five years.
But I still think about installing the boots...
Old Dec 9, 2013 | 02:47 PM
pwdrhound's Avatar
I can verify that the boots will not trap any dirt or moisture in. I have actually removed the boots to check just because of hearing this. I have run the car in huge downpours and checked the joints afterwords. They were bone dry when the boots were removed.
Old Dec 9, 2013 | 02:55 PM
TurboTodd's Avatar
Thanks for the input. I will defiantly consider this based on your experience.
these guys have some nice ones
http://www.sealsit.com/rodendboots.asp
Old Dec 9, 2013 | 03:25 PM
pwdrhound's Avatar
Probably the same boots Tarett sells. That's the ones I have. They sell two sizes. The rear drop links use the small ones, the front links use the large ones.
Old Dec 9, 2013 | 03:33 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
I have some extra boots (large and small) from Tarett if you are interested.
Old Dec 13, 2013 | 09:45 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
After snapping the stock rear drop links, I went with Tarrett. They are bullet proof but can be a touch noisy.
Old Jan 2, 2014 | 02:30 PM
TurboTodd's Avatar
Okay so I just received my new boots. Install was simple and they do appear as though they will protect the rod end. I used the RERS 1 on the tarett rears. Next its the TRG fronts. I think the fronts will need the size 2 or 3 boots. I'll let you know and post pics as to what fits.
ID:	316869   Click image for larger version
ID:	316870   Click image for larger version
ID:	316871   Click image for larger version
Old Jan 2, 2014 | 06:57 PM
32krazy!'s Avatar
pm me what you want for them and how many you have. my car is loaded with gmg adj links from front to rear
Old Jan 2, 2014 | 07:59 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
TRG Front Drop Links Installed with Ohlins TTX46's:
ID:	316969   Click image for larger version
Last edited by VID997; Jan 3, 2014 at 12:24 AM. Reason: Found another image to add.
