can't put gas in my car
Old Dec 30, 2013 | 01:23 PM
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
can't fill the tank with any amount of gas.. any hints?
Old Dec 30, 2013 | 01:40 PM
CTDan's Avatar
CTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond repute
This site seemed to have a few ideas...
http://forums.rennlist.com/rennforum...-take-gas.html
Old Dec 30, 2013 | 01:46 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Turn the nozzle upside down. There are times when mine stops at 3/4's full and I simply turn the nozzle upside down to fill the rest.
Old Dec 30, 2013 | 01:51 PM
krpt176's Avatar
krpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to behold
When I insert the nozzle I always have to tip it up or it stops every time.
Put the nozzle in, lift it about a few inches and start pumping.
It may just work.
Old Dec 30, 2013 | 01:54 PM
jpflip's Avatar
Fuse E6 ?
Old Dec 30, 2013 | 03:49 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
there is are a few post on this. most usually jump straight to blameing the carbon canister. i had same problem year or so ago. i took the plastic extension (6-10") off my 2 gallon gas can and took it to the gas station with me. i put it on the nozzle to extend the reach and pumped away. never had a problem since.
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
+1. Been doing it that way since I bought the car.
Old Dec 30, 2013 | 08:51 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I bought a ring (oem part) that clips on the filler opening for my 997tt. I would think it fits the 996tt as well? I would flip the nozzle upside down before getting the ring.
Old Dec 31, 2013 | 02:30 PM
PorscheDonTT's Avatar
PorscheDonTT is infamous around these parts
I literally changed gas stations to one that would allow me to fill the car.
Old Dec 31, 2013 | 02:33 PM
Wait, what is the OEM ring. Do you have a picture or a part number?
Old Jan 1, 2014 | 07:37 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
The Rennlist thread is good and there are a couple on 6speed (search is your friend). I always turn the pump handle to 9-o'clock position and it fills every time.
https://www.6speedonline.com/forums/...ll-way-up.html
https://www.6speedonline.com/forums/...-gas-tank.html
Old Jan 2, 2014 | 05:55 AM
'02996ttx50's Avatar
i also have this issue and also orient the nozzle to 3 o'clock and hold it ( pita ) but if i attempt to fill beyond the first auto shutoff, i have massive spillage which i have to believe is the canister(?) being flooded so i no longer go for the 2nd squeeze, but am still just at "full" using this method. it's a peculiarity but one not worth chasing down. yet.
Old Jan 2, 2014 | 07:51 AM
zracer196's Avatar
zracer196 is infamous around these partszracer196 is infamous around these parts
New to me 996 too. No problems with the fill but I cannot add ANY fuel after it trips. It will spill over for sure. But my car does go to the full mark also.
Old Jan 10, 2014 | 12:32 PM
mod mike's Avatar
easy fix. i took off the cap for the gas tank and disconnected the top breather. the car filled up, and i put it back on. will take it to my guy and have him fix the air breather hose so i don't have to do this each time i fill up...
Old Jan 10, 2014 | 12:40 PM
jpflip's Avatar
Hum... that's interesting! This is something to look at in the future. Of course if the air cannot come out the fuel won't go in!!! thanks for sharing!
