How low is my car?
How low is my car?
I bought it set up this way, and it rides fine, and seems like the PSS9 is on a pretty soft setting...anyway when I looked at the fronts they were.
I don't really want to raise/lower the car, but for reference on wheel/tire fitment.
What do you think...here is a pic.
It doesn't look all that low. Measure it from the factory measurement points. I think it's a bolt head in the front subframe and a flat machined spot on the rear. Then there is a chart floating around with all the factory ride heights (996, turbo, x73, gt3, etc) that you can compare to.
No fender rolling, as far as I know stock liners. (I bought the car with stock wheels and tires, so pretty sure they are stock.)
I have the BBS RS-GT's, they are 18x8 ET 50, and 18x11, ET 45, which is the same as stock I believe.
Your wheel fitment/tire selection, ride height and suspension geometry will entirely depend on your wheel specs. Given your height, you seem to have a lot of room / clearance. Shoving something wider and more aggressive may change that and suspension damping (compression/rebound) may come into play as well depending on what performance mods you have and your driving style.
The PSS9 kits have a very small height adjustment range clearly spelled out in the installation instructions, 5-10mm. Do not go lower to avoid bumps stop issues... Many people disregard this and then wonder why their car is handling funny.
