Added a little power, Transmission lost 3rd gear.
SubscribeQuote:
interesting do you hear it over the exhaust?Originally Posted by BlackHorseTurbo
Just drove the car for the first time. The straight gear whine is not bad at all. Actually I kinda like the way it sounds! Can't wait for a full boost pull!
Quote:
During certain points of the rpm range like decel you can hear the gears. But you can't hear it during cruising or accel. It sounds pretty cool though.Originally Posted by OS Inspector
Quote:
interesting atleast not as bad as expected.Originally Posted by BlackHorseTurbo
Yes it is. The 997 gt2 has the 3mm wider journal and the gear that was put in was thinner so they needed to make up the space. About the same spacer is on the pinion shaft too I would say.
