Removal of CATS from stock exhaust
Old Sep 10, 2005 | 08:17 PM
cgmeredithjr's Avatar
cgmeredithjr is infamous around these parts
Has anyone removed the 4 - 200 cell cats from their stock exhaust? I spent the day modifying my stock GT2 muffler with a large pry bar and hammmer (hours of prying, crushing and manipulating). An easier method would have been to cut the exhaust, remove the CATS, then re-weld. I love the Fabspeed Super Sport, however, I have a hard time conversing on the phone while in the car, and my neighbors are starting to think that I have a piece of heavy equipment in my garage every time I do a cold start. The Fabspeed will still be used at the track, I just need something quieter for the street. I know that the stock exhaust will increase back pressure, but how much of that back pressure is caused by the 2 large blockages (after each turbo) called catalytic converters? How will a "CAT less" stock muffler compare to a Fabspeed Super Sport with 100 cell CATS?
Well, I removed the CATS and will test the system tomorrow. Hopefully I won't get a CEL, but if I do, I have a reader to reset. The exhaust "looks" a lot less restrictive; the expansion chambers directly after the turbines are wide open now which should promote flow and reduce back pressure and be more quiet.
Buddy, I not a ***** or getting too old!
Cleve
Old Sep 10, 2005 | 09:01 PM
buddyg's Avatar
The cats even 100 cell definately block airflow. Looked at mine today versus the cat bypass which is basically the Fabspeed cat with nothing inside.
My dealer installed the bypass and straight pipes today and no CEL. You have to mount the O2 sensors somewhere and the fab bypass pipes has the built in locations.
I think I might just keep it this way for the street! Sound bad to the bone.
Even the fabspeed exhaust creates a loss of 5 psi of boost at least it did on my car.
Old Sep 10, 2005 | 09:05 PM
buddyg's Avatar
And by the way Cleve you are an old *****!
j/k
Old Sep 10, 2005 | 09:10 PM
I'm only 37, but I do think that I am going deaf!
Cleve
Old Sep 10, 2005 | 10:55 PM
Ken's Avatar
Ken
Ken is a jewel in the roughKen is a jewel in the roughKen is a jewel in the roughKen is a jewel in the rough
Buddy, do you have any avi or mpeg files of the exhaust sound?
Old Sep 10, 2005 | 11:13 PM
PorschePhd's Avatar
Cleve,
It will throw codes and cause a drivablity issue.
Old Sep 10, 2005 | 11:22 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
move out of the suburbs!
Old Sep 11, 2005 | 02:36 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Just say NO to cats!!!
Craig
Old Sep 11, 2005 | 05:16 AM
buddyg's Avatar
I will try to record today not real sure how to do it though?
Old Sep 11, 2005 | 05:46 AM
Ken's Avatar
Ken
Buddy - you have PM
Old Sep 11, 2005 | 07:53 AM
Originally posted by PorschePhd
Cleve,
Dammit, I knew I should have consulted with the Doctor first. Stephen, what kind of driveability issues? I do not want to do anything that could damage the motor. I assumed this would be a good compromise...low back pressure with chambered muffler...cheap too!
Cleve
Old Sep 11, 2005 | 07:57 AM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Hey Cleve you need one of our exhausts
Old Sep 11, 2005 | 08:01 AM
Out of $. Got one I can Borrow?
Cleve
Old Sep 11, 2005 | 12:53 PM
Zippy's Avatar
I believe you can fab up some cat material around the O2 sensors to trick the ECU into thinking you have cats. Seen it done before - no codes.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
km90265
Aug 31, 2015 11:00 AM
Vrseis
Aug 20, 2015 07:41 AM
oddjob142
Aug 19, 2015 12:27 PM
