replace just cv boosts or entire axle
Old May 5, 2014 | 02:03 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I know my front cv boots are torn and grease is coming out, should I replace entire axle or just boots I'm not sure how long ago that happened
Old May 5, 2014 | 02:05 PM
rmc1148's Avatar
I in the past always just replaced the axle but I guess it would depend how many miles they have been in use.
Old May 5, 2014 | 02:08 PM
MadWhip's Avatar
That I dont know since I bought the car like that way, plus i know it can save you a headache by replacing entire axle
Old May 5, 2014 | 02:55 PM
rmc1148's Avatar
Yes as they have to be cleaned well,,checked for excessive ware and greased = much easier to just replace.
Old May 5, 2014 | 06:05 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Mine was sent out to be refurbished. I believe it was $400 if I remember well.
Old May 5, 2014 | 07:45 PM
rmc1148's Avatar
I haven't looked but cant rebuilds be had on an exchange basis.
Old May 5, 2014 | 07:51 PM
FI_FTW's Avatar
Good point. I thought they refurbished mine but maybe they just sent an exchange pair? My mechanic sent them out at the time. I also went in for cv boots but he told me there was a little vibration from the front end (hence the refurb).
Old May 5, 2014 | 08:14 PM
rmc1148's Avatar
On all the cars I have worked on I just exchanged but do realize 996tts are not common so maybe not.
Old May 6, 2014 | 07:27 AM
kylehohlier's Avatar
kylehohlier has a spectacular aura aboutkylehohlier has a spectacular aura aboutkylehohlier has a spectacular aura about
really just depends on the condition of the joints and if how much money you want to spend, i'm about to replace my boots. a lot cheaper than dropping for a new axle. Luckily i dont think my joints are too worn yet.
Old May 6, 2014 | 10:47 AM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
I just had all four front CV boots replaced on mine. Three of them were torn, 4th was preventive. My mechanic took the axles to an axle shop to be inspected/rebuilt if needed.
A replacement boot kit is about $45 and a new axle is $650. It's a pretty big difference. As long as you catch a torn CV boot early, there is not reason you should need new axles.
Old May 6, 2014 | 11:17 AM
ECS Tuning - Porsche's Avatar
We offer have a kit for either the inner or the outer boots. For more information Click Here. Let me know if you have any questions.
Old May 6, 2014 | 11:29 AM
MadWhip's Avatar
Thanks! I will check-if I need inner boots as well, as far I can tell I need 2 outter, : I placed order for Turbo Intake Plenum this morning ES#1483665----
Old May 7, 2014 | 11:12 AM
Thanks for the support MadWhip. If you ever have any questions feel free to PM anytime.
Old May 7, 2014 | 06:40 PM
nimski62's Avatar
nimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nice
Why would the plenum need replaced if you found oil in it? Can't it be cleaned?
Old May 20, 2014 | 10:12 AM
MadWhip's Avatar
I replaced plenum because it was leaking from the top/seal - after doing boost leak test. - Can't replace seal, took me 4 hours to replace it without dropping the motor.
