ABS fail at 160+
ABS fail at 160+
Because race car, no fender liners left. Saw a frayed/separated wiring harness in the right front wheel well at the track. Hadn't caused any problems up until then so I just used electrical tape to prevent contact and zip ties to get them out of the way.
That is until trying to brake into turn 10a at Road Atlanta at 165 or so. Heard a squeal, hiss, pop and barely managed to stop short of the gravel. Destroyed right front. Needless to say the wire resembles the sensor wire that runs to the brakes but seems to be the continuation of it that runs through the top of the wheel well.
Can't find a part # for it in the shop manual. Anyone have an idea?
May be you will found your answer here post #110 from D_Nyholm: https://www.6speedonline.com/forums/...already-8.html
PelicanParts.com
Sep 25, 2015 03:17 PM
