mobil 1 0-40
Old Jul 16, 2014 | 12:55 PM
DNugget991GT3's Avatar
mobil 1 0-40
5 quarts $22. Pretty sweet deal guys. check it out.
http://www.walmart.com/ip/Mobil-1-0W...Quart/23636902
Old Jul 16, 2014 | 02:51 PM
johnspeed's Avatar
Thanks,
They also have 15w50 for that great price..
I would and have mixed 50/50 of 0W40 and 15W50 before..
I don't like to run 0W40..
Old Jul 16, 2014 | 03:00 PM
BGW17's Avatar
BGW17 is infamous around these parts
walmart is where i buy oil at too.
Old Jul 16, 2014 | 03:17 PM
what would you guys suggest i run at 81k miles ?
Old Jul 16, 2014 | 04:26 PM
johnspeed's Avatar
I would think because of wear factor and bigger clearances with your miles ,, to go with 5W40 at least..
Old Jul 16, 2014 | 05:09 PM
Drew959's Avatar
Drew959 is a jewel in the roughDrew959 is a jewel in the roughDrew959 is a jewel in the rough
The consensus is 0w40 isn't great. I run 15w40 (Rotella T6). The mobile 1 TDT 15w40 is good too.
Old Jul 20, 2014 | 09:23 AM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
Would 5w50 be ideal for a higher mileage car in a very warm climate?
Old Jul 20, 2014 | 09:38 AM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
Um, pretty sure those are both five weight forty oils. Not fifteen. Don't want a typo screwing up a new guy's engine.
Old Jul 20, 2014 | 12:04 PM
Macster's Avatar
If whatever oil you have been using got the engine to 81K miles with no issues arising from oiling why change?
There is no real reason to change oil grades other than a change to accommodate a change in ambient temperature.
If you drive your car year 'round you can if you want to switch to 5w-50 (not a typo for 15w-50!) for the summer months then switch back to 0w-40 (or an approved 5w-40) for winter driving that's your call.
Where I live it doesn't get that cold so at 125K miles on my Turbo at its next oil change I'm having the dealer use 5w-50 oil. I switched my Boxster to this oil last oil change and will stay with this oil going forward.
However, both the Turbo at over 120K miles and the Boxster at 280K miles have no issues with 0w-40 oil. The engines idle quiet, and with the Turbo and its oil pressure gage I see no low oil pressure even at hot idle.
You should never mix oils. With oils the additive package is very important, critical in fact, and by blending two different oils you end up with some Frankenstein oil that has only half of each oil's addictive package and in which the additives may work against each other rather than work together.
Old Jul 21, 2014 | 05:48 AM
'02996ttx50's Avatar
I mix oil weights ( not brands ) and if I have a problem, that isn't it. I'll never run 0-40 again it is just too thin for the ambient temps. I run a 60/40 mix of 0-40 & 5-40 in the cooler months and same ratio mix of 5-40 & 5-50 castrol edge cpl weeks ago. Since switching to the heavier blend(s) I have yet to hear an awful oil starved screech at startup. But I'll make s final judgment on that once temps are 100+ daily. This week it'll be 105+ so I'll be listening lol
The suggestion to mix the 0-40 w 5-40 came to me from guys that prep and race pcars here. Its fine.
Old Jul 21, 2014 | 05:58 AM
pwdrhound's Avatar
I run Mobil 1 5w50 tracking the car in 100+ degree weather. Good oil. Factory fill on the 997GT2RS...
Old Jul 21, 2014 | 06:02 AM
Originally Posted by pwdrhound
I run Mobil 1 5-50 Factory fill on the 997GT2RS...
That's good info.
Old Jul 21, 2014 | 06:55 AM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Just switched from Mobile1 0w-40 to Castrol 5w-40 and the engine is quieter. Less "loose marbles in the crankcase" sound...
tita1989
Aug 17, 2016 03:13 PM
EZ Cookin
Feb 9, 2016 11:25 AM
dphouse
Detailing
Sep 15, 2015 12:55 PM
HIX
Sep 9, 2015 04:45 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
