plenum Crack
Old Jul 29, 2014 | 09:15 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
plenum Crack
Big u shaped Crack on the plenum around the stand off that holds the aluminum intake . Fixed with epoxy and sst parts. It must have started a wile ago because the car has never been this fast.
ID:	397859   Click image for larger version
ID:	397860   Click image for larger version
Old Jul 30, 2014 | 07:13 AM
jpflip's Avatar
Same problem here. Discover the crack when my engine was removed for coolant pipes welding. Fix it with fiberglass. Hope it will last!
Name:	Screen Shot 2014-07-30 at 09.09.51.jpeg
Old Jul 30, 2014 | 09:40 AM
TeCKis300's Avatar
TeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of light
Another **** poor plastic fantastic part from the factory. Not impressed.
Interested though in what kind of mileage your vehicles have and if it's due to stress related to the number of heat cycles, etc.
Old Jul 30, 2014 | 10:03 AM
supra.z06's Avatar
supra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant future
Op: I have one forsale if your in need... $47 shipped.
Old Jul 30, 2014 | 10:38 AM
mbgt72's Avatar
mbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud of
It's easy to crack it if people aren't careful when lowering the motor. That's the bolt that attaches to the intake hard side, which also attaches to the body of the car. I.E. if you drop the motor too much, the weight gets put onto this plastic piece if that bolt isn't removed. When I dropped my motor last month, it was obvious that it'd been out before as that back bolt wasn't even there, and I'm quite okay with that. Luckily, Todd @ Protomotive warned me about that very specific bolt before I did the engine drop.
(Just mentioning all this as a general PSA for other owners who may drop their motor in the future)
Old Jul 30, 2014 | 10:47 AM
jpflip's Avatar
In my case 50,000 miles. I think mbgt72 is right about stress on removal or stress related to poor intake attachment...
Old Jul 30, 2014 | 10:48 AM
jpflip's Avatar
Agree!
Old Jul 30, 2014 | 11:18 AM
TeCKis300's Avatar
Whew. Good to know this is not another unforced failure like the coolant reservoir tank.
Old Jul 30, 2014 | 11:21 AM
rmc1148's Avatar
Can the bolt be gotten to and is it visible in plain view?
Old Jul 30, 2014 | 12:15 PM
jpflip's Avatar
Just went to look at my repair to see if it is holding and I had to use the borescope…Not the best place but with the engine lowered 4 inches this can be inspected properly...
Old Jul 30, 2014 | 12:28 PM
rmc1148's Avatar
Thanks was just curious if the bolt could be removed prior to lowering to save broken plenum?
Old Jul 30, 2014 | 01:44 PM
mbgt72's Avatar
Yes, this is what the instructions call for. The motor is able to be lowered ~2" or so, and then the manual requires that you remove the plenum bolt as well as some others to lower the motor further. But as I mentioned, I see no reason to install the rear plenum bolt as everything is pretty secure as is without it.
Old Jul 30, 2014 | 01:46 PM
rmc1148's Avatar
Thanks for answer=got it!
Old Jul 30, 2014 | 03:33 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
iv got a couple
Old Jul 30, 2014 | 05:42 PM
raineycd's Avatar
I has this issue as well - put the wrong bolt in my drop links and it hit the intake worm clamp near the turbo and pushed the intake up and broke the aluminum plenum mount off and cracked the plastic intake distributor. So if you have aftermarket links, check clearance.
