DIY: MAF cleaning
Dock, I am glad that it worked out so well for you. I assume that you got to drive it? So, the hesitation that you talked about in the high rpms is now gone?
I still need to make it up to your place and datalog your car. I'd be curious to see how your fuel trims measure up to mine with your new programming.
For everyone else with questions/concerns on this DIY cleaning: I've run my car for the last 2 days with no ill effects for about 100 miles. I've datalogged my fuel trims and they are MUCH more stable than they were when the MAF was dirty. There have been NO CELs (knock on wood) and the car's response is more smooth and crisp. I figure that the worst I will be out is the price of a new MAF.
Originally posted by jags911tt
Ruiner - great, I happy that it fixed your problems too. 300 miles and no issues yet for me.
Jags
Jags
Hey Ruiner - based on your knowledge of the numbers read on your data log, would a slight MAF problem, causing somewhat skewed FT's, degredate power levels? To what degree would you estimate? I've noticed some bucking in just off idle speeds in first and to a much lesser degree in second. I don't remember this happening when the new MAF was installed. Perhaps a little more oil has been sucked off the filter and stuck to the MAF? I'm going to pick up a can of your reccomended spray and see if it goes away. If I'm real ambitious, I will do a before and after datalog also.
My numbers, however, were bad enough to trip a CEL code (P0175 and P0172). The thread below explains a bit more.
https://www.6speedonline.com/forums/...threadid=30929
Basically, my STFTs were sitting around -20 to -25% for both banks while at idle. That would eventually throw the CEL. The code was only tripped at idle, however. Idle/low speed is where metered air really has an issue with fuel management.
Contaminating the MAF with oil from a filter is highly possible and most likely the cause given the power of the turbos to suck in large amounts of air under full boost. Mine was contaminated and I have a stock filter that was replaced 5k miles ago!
Like I said, just get an electrical cleaner (Radio Shack, Home Depot, Ace Hardware, etc) that leaves NO RESIDUE. That is the most important fact. Once it cleans the MAF, leaving no residue enables the MAF to function as it was intended without obstruction(s). Try measuring your car's air flow as well. Do a few logs: Air flow, RPM, O2s, STFT, LTFT, throttle position, etc. Mix them up and see how they interact with each other. Then, clean your MAF and create some new logs to compare. My STFTs were night and day. After a hard run, my STFTs are around -4 to +4% instead of -20 to -24% across the board.
Maybe this will fix your problem, maybe it won't. It can't hurt to try as long as you are careful. You will do no harm to the MAF. If it doesn't work, at least you rule out a contaminated MAF as being the cause. Good luck and let me know how it goes!
Originally posted by Big Carrot
Where did you find the cleaner? Radio Shack or something?
Ruiner, I've been having very similar problems as Dock (Atlanta) and want to give this fix a try but I have a few questions. Everything I've heard about MAF's is that they are very fragile, what should I be careful about when removing and cleaning it. How do you remove the elec. plug from the MAF and since I have been useing a BMC filter it probably makes sense to switch back to a stock one after cleaning. Could this problem affect boost levels. Can't wait to give this a try.
Yes, it could affect boost levels somewhat, but you don't have to remove the BMC air filter after you clean the MAF. If it gets sluggish, you can always clean the MAF again.
Forgot to mention that I have not had any CEL issues at all. Can the MAF be contaminated with oil and cause problems like Dock explained yet not cause any CEL issues.
Dock didn't have any CELs; I don't remember him having any, at least. I think that you could have the same issues and not show a CEL....yet. It takes a few cycles for CELs to generate and come up. If the conditions aren't right, you won't get a CEL even though there is restricted/sluggish performance.
Thanks Ruiner, I'm going to do it by the end of the week and I'll post results. Thanks, these problems have been bothering me for a while.
