New Turbo... to X50 or not???
Old Sep 30, 2005 | 12:31 PM
Lizard1's Avatar
Lizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of light
Currently searching for the perfect 996TT but have quickie question:
I will undoubtedly in the future do the Stage whatever upgrades to increase HP/torque so would it be a waste to get the X50. I'm not sure if the upgrades would essentially cancel out the X50 package or be in addition to?
thanks for any help
Old Sep 30, 2005 | 12:36 PM
Ruiner's Avatar
Frank, with the onset of hybrid turbos, you can really reduce the lag that the K24s bring to the table and still develop more horsepower. If you plan to mod (especially the turbos), you would be better off saving the extra $4-6k (?) that you would spend on the X50 over the K-16 based turbo. What is the asking price for an X50 over a standard turbo? Granted, you will get bigger intercoolers (10%?) and a beefier tranny (has this been confirmed?). It's up to you, honestly.
Old Sep 30, 2005 | 12:41 PM
Lizard1's Avatar
b - pm me your telephone # por favor
Old Oct 2, 2005 | 07:16 AM
Lizard1's Avatar
so i've searched the archives...
it appears that the X50 actually has less "pull" than a stock tt at RPM's less than 4000 and the power advantage is seen in the higher RPM's??? This had to be inferred from several posts/graphs
Does this sound right?
Old Oct 2, 2005 | 09:29 AM
Ruiner's Avatar
Basically, yes. Lag is the name of the game. The K24 turbos shine on the high end while the K16 turbos are great down low. Once the K24s spool, they are brutal, but the lag is a good bit more than the K16s. It really depends on where you want to sit with your RPMs - low (K16) or high (K24) or....both with a hybrid setup.
Old Oct 2, 2005 | 10:17 AM
EXPLICIT's Avatar
EXPLICIT is infamous around these parts
Stick with K-16's. Push the envelope and see if your willing to negate some driveability with lag and upgrade the turbos for more top end grunt.
Old Oct 2, 2005 | 10:20 AM
Lizard1's Avatar
Originally posted by EXPLICIT
Stick with K-16's. Push the envelope and see if your willing to push the driveability with lag and upgrade the turbos at a later date.
i think that's what I'm going to do. i'll be happy just driving a turbo - my previous two porsches have been NA
Old Oct 2, 2005 | 10:45 AM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
Keep in mind if you can steal an x50 you are in great shape to mod because you don't need to change your turbos. Sure you may have some lag but once you get a new ecu and everything you will have so much power it won't be the end of the world. Basically if you want modding to be easier get X50 if you want the best performance money aside get K16s then do a hybrid later on.
Old Oct 2, 2005 | 11:08 AM
Ruiner's Avatar
Honestly, I would rather have the hybrids than the K24s. Even if I had K24s, I would probably get rid of them in search of a more streetable turbo setup (aka, hybrids of some type or ball bearing).
Old Oct 2, 2005 | 03:27 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Frank,I will have a PSI 550 at the shop soon with k24/26.
Neil
Old Oct 2, 2005 | 03:35 PM
Lizard1's Avatar
Neil
sounds sick - let me know when you get it & i'll come check it out....thanks
sharkster's Avatar
Neil I will be naked soon.
Old Oct 2, 2005 | 04:34 PM
Neil@Orton's Avatar
Will do,
You can then come back and try it after the conversion is done.
dkfx
Apr 21, 2016 01:58 PM
Stormdog
Sep 26, 2015 03:18 PM
webcarconnection
Sep 21, 2015 10:54 AM
I-Man
Sep 17, 2015 05:31 AM
