slight knocking on the steering wheel...
Hi, I feel a slight knocking on the steering wheel, when car is slowly moving forward on broken pavement or small bumps.
I've replaced the top mounts and the top/low control arms. What other causes can contribute to this?
Thanks!
Thanks!
That's just the puzzle... The movements did not produce any play - left-right or up-down. At least not the obvious parts in the suspension...
When the car picks up speed, the knocking is no where felt. Only when the car goes very slow, can you notice the slight knocks only the steering wheel...
The shocks/parts are stock.
Thanks.
Check the power steering fluid level.
A partial list would be a broken sway bar link; a loose/broken sway bar mount bushing; any steering or suspension bushing including the rear ones... cars have a funny way of making a noise from one end of the car appear like it is coming from the other end...; motor/transmission mounts; and any loose/cracked/missing body underpanels, including the fender well liners.
I'd go so far as to expose the power steering rack and the steering hardware -- based on the underbody areas of cars I've seen this will require one or more plastic underbody panels be removed -- and check for anything loose or worn. Check for any other lines or hardware, brackets/etc loose or out of place. While you there check the steering rack dust boots for any presence of fluid. Give 'em a squeeze, but not too hard cause if they have any fluid the squeeze can cause the boot to pop and spray you with power steering fluid.
With the car supported by its body lift points you (or your mechanic) can grasp and give all the steering, suspension hardware a good shake to check for any excessive play or looseness. Look at the springs for any signs one is broken
Check brake lines are properly routed and held secure to prevent any flopping about.
Last (or maybe this should be first...) be sure there is nothing: a bottle, can, golf ball, something; loose in the front trunk. (Be sure the spare tire and all the tool kit hardware, jack, etc are secure.) Check the cabin too for any loose foreign object and this includes of course under the seats. Watch it there are some edges/pointy things under there!
I got this from another board, done by Macster. - Since im that lazy to type
Studio RSR
Audi
Nov 10, 2015 07:05 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
