Fuel Pump needs replacement - what direction?
Old Apr 19, 2015 | 12:48 PM
  #181
hydra.'s Avatar
hydra. is just really nicehydra. is just really nicehydra. is just really nicehydra. is just really nice
Gents,
On an unrelated note, doesn't anybody run a 3.0 bar FPR instead of the stock 3.8 bar to extend fuel pump capacity just a little bit more? Sure you'd need to size your injectors 12.5% bigger, but it would help increase fuel pump throughput while decreasing current draw...
Old Apr 19, 2015 | 01:10 PM
  #182
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Ive set my static pressure at 3.5 bar
Old Apr 19, 2015 | 01:27 PM
  #183
hydra.'s Avatar
I was talking about using a bolt-on, off the shelf non-adjustable 3.0bar Bosch regulator to get the pressure down. Perhaps a Bosch PN 0 280 160 557 would drop right in?
Old Apr 23, 2015 | 12:21 PM
  #184
SamboTT@ByDesign's Avatar
Hydra - I think most all run about 3.5-4bar. Just depends on the tuner and what the set-up likes. The pumps can support more pressure easily and a well rounded system will keep the pressure under control. Some have had issues keeping it down actually with small returns or low capacity regulators.
***** - Yes same set up. In stock if you need that or anything else. Just let me know!
Jun 10, 2017 07:45 PM
SharkyShark20
Sep 19, 2015 09:54 PM
tkebp1275
Aug 31, 2015 06:35 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
TrackOne
Aug 20, 2015 12:56 PM
