Diy clutch change??!
Subscribe
Nov 22, 2014 | 02:18 PM
  #46
Does the shaft come all the way out?
I threaded in the bolt and it moved substantially
Reply
Nov 22, 2014 | 02:23 PM
  #47
Pull it out completely! Of course the fork will fall inside because it is not taped but it will be on reinstallation
Reply
Nov 22, 2014 | 02:28 PM
  #48
Next step is to separate the transmission! Good luck with this part and remember it is heavy! Around 160 pounds!
Reply
Nov 22, 2014 | 03:02 PM
  #49
And there you have it.
Reply
Nov 22, 2014 | 03:04 PM
  #50
Did I mess up my slave cylinder? It wasn't out of the trans all the way when I dropped the trans.
It seems like all it did was pull the rod out. And went right back in. Ideas?
Reply
  #51
Congratulations Stilov!!!!
Reply
Nov 22, 2014 | 03:05 PM
  #52
Remove the rubber boot at the end of the slave and you will see the pushrod is free inside….
Reply
Nov 22, 2014 | 03:08 PM
  #53
Now it is time for a good inspection , of course of the clutch, pressure plate and bearing but also the needle bearings for the clutch fork. Both sides should be inspected properly….
Reply
Nov 22, 2014 | 03:09 PM
  #54
Stupid triple square bits I bought won't fit the clutch! M8 is like a hair too big.
Is it seriously m7?
Reply
Nov 22, 2014 | 03:12 PM
  #55
Sorry cannot remember….
Reply
Nov 22, 2014 | 03:17 PM
  #56
My clutch creaked really bad prior to this, something inside the bellhousing. Kevin at UMW suggesting the roller bearings, so I need to look at everything. I really hoped to get the clutch out to figure exactly what I had in the first place.
Reply
Nov 22, 2014 | 03:20 PM
  #57
Looking for the proper tool I have found this useful link: https://www.6speedonline.com/forums/...h-install.html
Reply
Nov 22, 2014 | 03:24 PM
  #58
those are the instructions I used. I wish someone knew for sure what size of 12pt socket I need...
the only thing I did differently was pull the accumulator off the slave to get to the bolt...way easy
Reply
Nov 22, 2014 | 03:38 PM
  #59
One of the best tool I bought was a set of torx star socket from Sealey. Order it from England. I use this tool often used and it is very strong!
http://www.ebay.com/itm/SEALEY-LARGE...item2a14b12007
Reply
Nov 22, 2014 | 03:53 PM
  #60
Looks like you need a T-50 socket! I just found a DIY for a clutch replacement of a 997 and the bolts that hold the pressure plate is the same part# on our 996TT. The tool Rotmilky (the thread starter) used is a T-50 socket!
http://rennlist.com/forums/997-forum...-i-did-it.html
Many on Ebay and Amazon….
Be careful, your's is non oem, may be different type of bolts!
Reply
