Anyone using the AEM Infinity?
Old May 27, 2015 | 11:05 AM
  #106
rtype16's Avatar
rtype16 is infamous around these parts
Originally Posted by onenrg1
Yes. I checked the pinouts and it looks to be the same for both 996/997. Just wire the 997 to the same wire and you should be good to go. I was curious about the 997 turbos on a 996 and checked that the pinout for the 996 are not used so you could just wire the 997 turbos actuators to the free pinouts on the harness and just turn them to operate in the AEM.
The 997 turbos can be used on the 996 and wired in to work correctly.
The Uprights however will not work with the AEM unit. It is pulling the wheel speed data directly from the CAN system so it has no control over what it is sending out or receiving. So basically if you cant get it to work with the factory ABS CAN system than the AEM will not see it.
Old May 27, 2015 | 05:58 PM
  #107
BLKMGK's Avatar
So no issues controlling the variable vane with the 996 flash? nothing funky in the 997 flash for it?
Old May 28, 2015 | 04:00 PM
  #108
rtype16's Avatar
Nope just wire the inputs and outputs in like the 997 and activate it through the tables.
Velgen
Other Japanese Supercars
Sep 17, 2015 11:20 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Velgen
Sep 3, 2015 12:28 PM
Velgen
Aug 19, 2015 01:45 PM
