Spring removal mod - clutch
Old Mar 6, 2015 | 08:01 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I'm looking to remove spring helper from the clutch *mod* trying to find the link i saved somewhere it explained with picture what to remove....
do you guys have link to that, I would like to try the mod and do it over the weekend - I do not need Cruise control - I never use it anyways.
Old Mar 6, 2015 | 08:52 AM
there is a little bucket up by the top of the pedal and the spring sits inside
#TeamAIM
Old Mar 6, 2015 | 09:01 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I started a thread years ago on Rennlist, it's still going in the 996 (NA) forum. I'm not a paid member so I can't link to it, but check there it's on the first page, maybe 2nd.
Old Mar 6, 2015 | 11:42 AM
MadWhip's Avatar
thank you! ^_^
Old Mar 6, 2015 | 02:03 PM
'02996ttx50's Avatar
pls post your take on the mod once done. I've wanted to do that and whatever it is these guys keep talking about that will lessen the unsprung weight on the _______ ? before one is engine running. what mod is that one?
oh, that and pdwrhounds psm "off" pump switch for the frunk. if i could just get those 3 little things done. that'd be nice.
just thinking out loud here. sorry mad lol
Old Mar 6, 2015 | 03:40 PM
BLKMGK's Avatar
You're thinking of the weights on the shift arms at the transmission?
Old Mar 6, 2015 | 04:46 PM
contsaga's Avatar
contsaga has a spectacular aura aboutcontsaga has a spectacular aura aboutcontsaga has a spectacular aura about
Helper spring DIY
There's several write ups on a DIY for this mod on this forum...unfortunately, I don't remember the links...do a search.
I did the Home Depot spring and found it better for me...I'm use to heavier racing clutches but I find this setup the best clutch feel...although, many like the MacMaster spring...I find it still helps me too much.
I've attached a couple of screen pix of the post...hope these help...btw, use the broom stick technique to put the helper spring unit back in...it's a god send!
Name:	Screen shot 2014-11-03 at 12.10.08 PM.png
ID:	415725   Click image for larger version
Name:	HD spring #.png
ID:	415726   Click image for larger version
Name:	Screen shot 2014-11-06 at 1.03.54 AM.png
Old Mar 6, 2015 | 04:52 PM
contsaga's Avatar
Also, as shown on the last attachment, be sure the Hexiganal end of the bolt is in the correct position...it's side specific...one side round, one side hex shape...
The HD spring is $4.89 and the MacMaster is about $3 each...you have to buy a bag of 6 springs + shipping charge.
Old Mar 6, 2015 | 04:54 PM
i think so it's the one the eliminates the pressure on the clutch part, name of which escapes me? is it the actual "weights" being removed? i just remember reading it was a "relatively" easy? mod e.g. clutch helper spring. then there's that and the mod eliminating the feature that requires "clutch engaged" at startup. i need a list on em lol
Old Mar 6, 2015 | 07:24 PM
32krazy!'s Avatar
i would avoid a mod that eliminates the nuetral safety switch. good way to drive your car thru the garage door.
Old Mar 6, 2015 | 08:28 PM
good point. but isn't that one also placing excess stress on the ( guessing..? ) throwout bearing? or what..?
some bearing or...
Old Mar 7, 2015 | 01:07 AM
BLKMGK's Avatar
Ah, some cars with heavy clutches have issues with thrust bearing wear being started with the clutch in all the time, not heard of that with these cars and I second the advice to not disable the neutral start switch. I thought you were talking about the weights back at the transmission that folks are removing to lighten up the stick.
Old Mar 7, 2015 | 04:26 AM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
I've had some reputable people advise of getting of the neutral safety.
If you think about it, all the old cars were like that anyway.
Old Mar 7, 2015 | 05:49 AM
32krazy!'s Avatar
they didn't have a/c or airbags either. i like both of them! the problem may not be with the owner but rather the new mechanic who didn't know it was disabled and you forgot to tell them. or your buddy who ended up driving you home after a few to many drinks.
Old Mar 7, 2015 | 08:06 AM
thrust bearing. thats it, thx. yeah, maybe i'll pass on the ignition/clutch bypass mod. but i'm gonna figure out that "psm" off switch in the frunk thing of johns, as psm off is usually part of my pre flyte checklist anyway
i'd like to also not have the added stress on the thrust bearing, but if that means i could inadvertently slam into a car in front of me or god forbid over one of those infernal parking bumpstops, then, yeah..
memory IS the first to go lol..and i probably shouldn't test that one. but i've never not engaged the clutch to start. but given i'm with stock hydraulics/shenanigans, any time i can avoid pressing the clutch ( out of habit ) i avoid it. though i often dbl clutch .. whatever...lol
