Additional Power for GT2
Old Jul 20, 2003 | 06:37 PM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
well i could use it in the straights... just like cocaine, i think i need more... HP and T.
i know i've said it doesn't need any more [i've changed my mind] but what ideas/experience do you guys have adding power to GT2???? if you blend smoothly out of the corner you could easily use another 100 HP/100 T on my uphill short straights here in the Sa Mo Mtns.
Ruf? FVD?
thank you
Old Jul 20, 2003 | 06:52 PM
oak's Avatar
oak
watt, do you use 100 octane?
Old Jul 20, 2003 | 06:59 PM
Ruf-Racer's Avatar
Ruf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura about
Watt-More Power?
Hmmm, wonder what's on your mind.
Cheers,
R
Old Jul 20, 2003 | 07:05 PM
watt's Avatar
oak,
what effect does it have? only available in sa mo canyon, right?
roland,
for the canyons, roland, the canyons... don't need it in other ... venues
Old Jul 20, 2003 | 07:12 PM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
Watt, you can make an adjustment to the waste gates,ecu,divertor valves and you will be at about 600hp and 650lbs of torque. That should hold you over for awhile.
Old Jul 20, 2003 | 07:23 PM
oak's Avatar
oak
Higher octane will allow much more aggressive timing and fuel curves. I fill up at the 76 off the 101 and Chesebro, Jack had turn me on to that location. Very conveniant, the price has been $4.25
a gal since last year.
Old Jul 20, 2003 | 07:25 PM
watt's Avatar
duane,
can you take me thru it in more detail?? i think that will hold me!!! thanks for your help.
watt
Old Jul 20, 2003 | 08:05 PM
Duane's Avatar
Bailey Divertor Valves
Evo Stage 4 Gt2 X50 program ECU
Exhaust of your choice
Steven at Imagine can tell your mechanic how to adjust wastegates if you purchase the ecu from him. This takes about 2 mins.
And boom wala you will have 600hp and 650lbs of torque. I have to imagine that this kind if power will be insane and harry in a Gt2. If you want call me in my office in the am. 305 682 2220
Old Jul 20, 2003 | 08:15 PM
watt's Avatar
yee faaaaaaaaaawwwwkin' haw duane,
sounds like fuuuuuun, talk to ya tomorrow. thanks
Old Jul 20, 2003 | 08:22 PM
PorschePhd's Avatar
Even if you don't buy the ECU from me I can tell you how to do it...
Old Jul 20, 2003 | 08:37 PM
WyattH's Avatar
WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !
Can someone tell me how to add power to my GT Pro Series (GT is a bicycle company). I was thinking of squating more at the gym... To generate more power with my legs on hills and whatnot...
I can also get contact info of a man who's username is Rocman (on different forums). He has a TT but it generates 600-650 hp. He is also in the Socal area.
Old Jul 21, 2003 | 11:12 AM
oak's Avatar
oak
watt, besides the obvious ecu tuning, exhaust, I would suggest a nice set of massaged turbos for aleviate some of the lag.
Old Jul 21, 2003 | 11:59 AM
watt's Avatar
oak,
what would your recommended package look like?
i thought gt2 already had spiffy turbo's????
ps i'll try the gas, thanks
Old Jul 21, 2003 | 12:13 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Although larger than the stock K16s and able to push more air, the GT2 K24s are less "spiffy" -- meaning they spool slower.
Old Jul 22, 2003 | 09:37 AM
HotRodGuy's Avatar
i'd also suggest getting some turbos w/ very minimal lag. Nothing is worse then being in a corner w/ the lag ends right in the middle of it. It'd be like driving a high HP supra, those things are very scary when full boost kicks in in the middle of a corner!
Michael_s
Sep 11, 2015 08:03 PM
orbelo
Aug 30, 2015 12:26 PM
Ferrari
Aug 24, 2015 04:35 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
