Boost Leak Question
Old Mar 17, 2015 | 05:59 PM
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
Boost Leak Question
I was doing a leak test today on my car for the first time. I found a leak coming from this hose circled in red. What hose is this, is this a common leak? Can I take off the factory clamp and use a worm gear one to fix it? Looks hard to get at because it is behind the oil filter housing any tips or tricks?
Thanks!
Old Mar 17, 2015 | 06:18 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
I can't tell which hose that is but I have replaced some of the factory clamps with the worm gear stuff because of boost leaks.
Old Mar 17, 2015 | 07:28 PM
mdurbahn's Avatar
Just tried that, It appears like the black plastic Y fitting is leaking and not the actual hose now. So much for the easy fix!
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
I have had several leaks from hoses with factory clamp, used worm clamps also and leak stopped, just don't over tighten.
Old Mar 17, 2015 | 07:34 PM
pwdrhound's Avatar
Thanks!
That is not a pressure line Matt. That is a vacuum line providing vacuum to the brake booster in the front of the car. I capped this line off after swapping to the 997GT2 vacuum pump. Hope that helps...
Old Mar 17, 2015 | 08:38 PM
mdurbahn's Avatar
Thanks John, If that is the case I must have a bad check valve somewhere I think..
Old Mar 18, 2015 | 05:55 AM
'02996ttx50's Avatar
the check valve just above the plenum is notorious for cracking. if you can pressure test from the turbo inlet you'll hear it hissing. it'll be that obvious. not sure from the pic its the area you've outlined but air box out, and near the plenum. if it is? change them both same time. cheap insurance, and they commonly go bad.
Old Mar 18, 2015 | 11:48 AM
its the black venture valve... replace and do another test
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 18, 2015 | 01:48 PM
mdurbahn's Avatar
Thanks, I have ordered a new one now.
Old Mar 20, 2015 | 03:26 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
How does this work? I have a new Venturi valve and when my var comes on boost for a split second the brake pedal is rock hard, I need to either fit a one way valve or run a separate pump.
Old Mar 20, 2015 | 04:03 PM
Slider's Avatar
I would love to hear the story about being on full boost with the brakes on - how does that work?!?!!
Old Mar 20, 2015 | 04:10 PM
No rock hard as in no power assistance! Its only for a split second as the car comes on boost.
Old Mar 20, 2015 | 04:16 PM
Slider's Avatar
How did you figure that out? I don't see how you can check the brake when your foot is on the gas all the way to the floor. Did you have one foot on the gas and the other on the brake?
Old Mar 20, 2015 | 04:32 PM
Ok so you accelerate away from a light and someone steps off the sidewalk!! Now in the UK we use the pedal in the middle (on a 6 speed) to stop! Ive now had 2 996 turbos that do this, its pretty simple, the line going to the servo has a vacuum in it, if it gets pressure you have no power brakes. You may think your being clever but im trying to figure out the solution to a problem here, do you think im making it up? If I accelerate hard and have to suddenly brake sometimes I have a rock hard pedal, its not rocket science.
In fact if your feet cant move fast enough to come off the throttle and brake while still on boost maybe you need to rethink your car or driving style.
Old Mar 20, 2015 | 04:59 PM
Slider's Avatar
Ah, OK that kind of explains it... By the time you move your foot from gas to brake, you are no longer at full boost (I guess close maybe). I've never gone full pedal with people that close, so that situation has never presented itself for me. Thanks for explaining it - I'll have to give it a try. I wasn't trying to be a di*k, I just didn't get get how you were getting there.
