Boost Leak Question
Old Mar 20, 2015 | 05:08 PM
'02996ttx50's Avatar
i thank johnnyd for explaining it also, as i've never really experienced anything like that either
talk about footloose and fancy free
Old Mar 20, 2015 | 06:38 PM
pwdrhound's Avatar
Originally Posted by johnny.dangerous
Ok so you accelerate away from a light and someone steps off the sidewalk!! Now in the UK we use the pedal in the middle (on a 6 speed) to stop! Ive now had 2 996 turbos that do this, its pretty simple, the line going to the servo has a vacuum in it, if it gets pressure you have no power brakes. You may think your being clever but im trying to figure out the solution to a problem here, do you think im making it up? If I accelerate hard and have to suddenly brake sometimes I have a rock hard pedal, its not rocket science.
In fact if your feet cant move fast enough to come off the throttle and brake while still on boost maybe you need to rethink your car or driving style.
This is a common problem that I have encountered myself at the track when you are hard on boost and do a rapid transition to hard braking. In many cases you will end up with a very hard pedal and little braking. This is caused by a lack of vacuum assist and manifests itself more at high altitudes or hot days where the air is even thinner (less vacuum). Basically the full throttle hard brake transition occurs too fast for vacuum to create brake assist. We ended up curing it by installing an engine driven vacuum pump as done on all the 997 and later TT/GT2/GT3 cars. The pump is off of a 997GT2. This completely cures the problem you are seeing. See my thread here on the conversion. https://www.6speedonline.com/forums/...tallation.html
Old Mar 20, 2015 | 08:09 PM
lets do the short list. what HASNT john thought of lol
Old Mar 21, 2015 | 04:06 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Originally Posted by Slider
Ah, OK that kind of explains it... By the time you move your foot from gas to brake, you are no longer at full boost (I guess close maybe). I've never gone full pedal with people that close, so that situation has never presented itself for me. Thanks for explaining it - I'll have to give it a try. I wasn't trying to be a di*k, I just didn't get get how you were getting there.
Its normally a sign of a faulty venturi valve but ive fitted a new one and even tried one from another car, keeps you on your toes when it happens, which isnt often as you say its an unusual scenario
Old Mar 21, 2015 | 06:40 AM
pwdrhound's Avatar
That won't fix it. That's the first thing I swapped out when trying to find a solution. There is only one thing that you can do to cure this..
Old Mar 21, 2015 | 08:12 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Check with mark from 911tuning . He will solve any leak issue
Old Mar 21, 2015 | 08:16 AM
As common as they are, I think boost leaks are overrated as "problems". There's only so many places they can occur. Although that might well be the jaundiced view from one who seemingly has had them all lol
Old Mar 21, 2015 | 09:43 AM
BLKMGK's Avatar
I've seen this happen on other cars of mine, I've actually had foot on the brake when boost has built and been shoved back in my seat as the pedal pushes back - it's no joke. Vac booster does,the opposite when pressurized. Sounds like the stock valve isn't acting fast enough for him and he's got transients often enough to notice it, Pwdr's solution is the best since it will divorce the brakes from any boost source.
Old Mar 21, 2015 | 11:56 AM
Any part numbers/pics of the install.
Old Mar 21, 2015 | 12:58 PM
Slider's Avatar
OK, I gave this a shot today. Not quite max boost but .8 bar and the brakes were fine. I'm not sure what to make of that, but, there it is.
Old Mar 21, 2015 | 02:21 PM
You can rest assured your venturi is fine dude My boost is 1.5 bar so was the other 996 that did it
It appears Pwdrhound has had the same issue and i guess this is why the 997 GT2 had a vacuum pump
Old Mar 22, 2015 | 05:24 PM
pwdrhound's Avatar
997GT2 oil scavenge / vacuum pump 997.107.022.72
997GT2 vacuum line 997.105.116.73
For pictures and a detailed description click on this link: https://www.6speedonline.com/forums/...tallation.html
Jul 29, 2019 11:13 AM
markski@markskituning
Aug 24, 2015 10:07 AM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
magoochi
Aug 23, 2015 05:54 PM
