Coolant drain : need some pointers (with pics)
Old Mar 23, 2015 | 05:57 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
Hi all,
I am in the process of a big 30K maintenance and as part of the preventative aspect of this also just replaced my water pump (the original one turned out to be unaffected though).
I now want to replace all my coolant with new G12 and so far have drained the engine (2 drain plugs in the rear).
Reading up on the forum, I know I also have to drain up front at the radiators and at some location close to the transmission.
Can somebody please chime in and confirm (or correct) my current thinking ?
1] I only see a drain plug on the center radiator (see attached picture). Is it sufficient to drain from this one location, or should I also unhook the side radiator hoses ?
2] See other picture showing the location of where I think the 2 lines close to the transmission need to be drained. Is this the correct location ?
3] I came across some references indicating to also drain the heat core, however those seemed to be geared toward the NA 996. Anybody know whether this also applies to our GT1 engines ?
Thank you in advance !
Yves
Old Mar 23, 2015 | 06:53 PM
mfbmike's Avatar
mfbmike is infamous around these parts
There is a thread somewhere that shows how to drain the engine, radiator, etc. of all of the coolant. I can't remember what it was titled but I'm sure someone will post it in here.
Old Mar 23, 2015 | 07:16 PM
Yves's Avatar
I did use the search function. Only found descriptions, nothing with pics.
Old Mar 23, 2015 | 08:27 PM
rmc1148's Avatar
I've not done the 996tt but on others I remove lower hose on radiator.
Old Mar 24, 2015 | 06:15 AM
eds966tt's Avatar
eds966tt is infamous around these parts
Perhaps while your in there replace the coolant tank as well. Are you doing the work yourself?
Old Mar 24, 2015 | 08:48 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
The coolant tank is a B!tch to remove with the motor in and not dropped or lowered.
Old Mar 24, 2015 | 10:25 AM
Yves's Avatar
Yes, I'm doing all the work myself, its kinda fun.
I have not considered replacing the coolant tank, is it really necessary ?
I did replace the fuel filter and the water pump last weekend which was a breeze with the engine lowered.
Coming back to my original question : are those the correct points to drain the coolant ? I searched everywhere on-line, went through the shop manual...nothing. Not even a diagram of the cooling system, very frustrating.
Old Mar 24, 2015 | 12:29 PM
jpflip's Avatar
Shop manual page 520 is specific about draining the system. The engine lowest point to drain is from the elbows (see pic) There are little thin washers to seal them. Never done the job so I cannot comment about drain location. Applying air to the hoses you had disconnected near the transmission and you will get rid of the old coolant from the radiators and hoses. Also removing one hoses connected to the lowest point of the radiator can also be a good procedure.
Name:	Screen Shot 2015-03-24 at 14.03.43.jpeg
ID:	416983   Click image for larger version
Name:	Screen Shot 2015-03-24 at 14.05.17.jpeg
ID:	416984   Click image for larger version
Name:	Screen Shot 2015-03-24 at 14.23.21.jpeg
Old Mar 24, 2015 | 08:31 PM
'02996ttx50's Avatar
incroyable
TheInfamousDrew
Sep 6, 2015 10:16 AM
faiz
Sep 2, 2015 08:43 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
