996GT2/TT oil dipstick conversion...
Old Apr 6, 2015 | 01:59 PM
32krazy!'s Avatar
Originally Posted by '02996ttx50
sure wish i had ..or could do this
sell those tacky taillights and you will have plenty of beer money to get your tech to do this!
Old Apr 6, 2015 | 02:05 PM
'02996ttx50's Avatar
hah! never wasn't a bad idea tho.. touché lol
Old Apr 6, 2015 | 06:51 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
This is great thank you!!
Old Apr 6, 2015 | 10:36 PM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
A very nice engine out upgrade!
Old Apr 8, 2015 | 01:28 PM
Mat59's Avatar
Mat59 is just really niceMat59 is just really niceMat59 is just really niceMat59 is just really niceMat59 is just really nice
This is a great idea/solution. However, to all those who are considering this as their oil level check function is broken on their cluster, check this thread first - http://www.renntech.org/forums/topic...l-not-working/
Old Apr 8, 2015 | 02:38 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Damn I would have done this while my motor was out !!!! Great Info dude
Old Apr 8, 2015 | 03:57 PM
32krazy!'s Avatar
quick update. the 31$ clip that holds the tube inside the filler tube is no were in the us. 42$ from germany ship time 3 weeks. if your doing this better order parts now!
Old Apr 8, 2015 | 03:59 PM
Does the electronic dipstick on the dash still work with this ????
Old Apr 8, 2015 | 04:00 PM
32krazy!'s Avatar
yes doesn't have anything to do with that
Old Apr 8, 2015 | 04:05 PM
Thanks dude, damn I wish you posted this 10 days ago !!!!!
Old Apr 8, 2015 | 05:25 PM
32krazy!'s Avatar
its pwderhounds thread so he gets all the reps. from what i can see you can drop the motor enough to get to the bolt holding the tube in place. order the parts and when you get them wait for the next oil change and drop it while changing the oil and swap it out. might have to remove the secondary air pump to get enough room but it should be able to be done
Old Apr 8, 2015 | 05:39 PM
pwdrhound's Avatar
IMHO, you will need a drop of 6" at a minimum. To go more than 3" or more, you will need to disconnect the fuel lines and coolant hoses along with the engine harness. You will also need to unbolt the sway bar and remove the crossmember under the engine. At that point, you can drop it...
Old Apr 21, 2015 | 06:56 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Originally Posted by pwdrhound
Here you go. This is straight out of 996GT3 Cup PET. You need #11, 12, 13, 14, 15, 16. You may not need 0-ring (#12) which I think is part of the cap #11. I can't recall though...
[url=https://flic.kr/p/rWfLPJ]
Could you kindly upload the 2 pages of the PET .pdf file showing the entire image and PNs associated with it? Thank you.
Old Apr 21, 2015 | 08:07 PM
john rice's Avatar
john rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to behold
At some point I may do my H2O fittings and this will be a priority if I have to drop the engine. THANKS. It would be so nice to see and smell the oil for real. I have older Porsches that allow this and it seems so idiotic that I can't in the newer cars.
PWDRHOUND- Thanks and Reps to you!
Old Jul 9, 2016 | 09:11 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
Dipstick goes into the guide tube. Guide tube goes into the filler neck which is then secured in the plastic fill tube via a retainer bracket. Then you bolt the whole thing on the oil tank in place of the stock one.
I just installed mine tonight, I had to remove the oil level sender and put the guide tube in the tank, on the mounting flange you will see a small grove where the alignment fork on the guide tube goes into place. Then i slowly and carefully wiggled the filler tube over the guide tube....
