996GT2/TT oil dipstick conversion...
Old Mar 31, 2022 | 10:59 AM
  #46
pwdrhound's Avatar
Originally Posted by BMiller33
The GT3 and TT oil tank is a different PN per the PETs....TT is a -72 GT3 is a -92?
Correct. The vent is different on the GT3 and TT tank.
Old Mar 31, 2022 | 11:36 AM
  #47
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
So do you need the GT3 tank for the conversion? If it's just the venting I would think not. Thanks.
Old Mar 31, 2022 | 11:44 AM
  #48
pwdrhound's Avatar
The vent has nothing do with this. Either GT3 or TT oil tank works with this conversion...
Old Apr 1, 2022 | 12:29 PM
  #49
TTMach1's Avatar
5 Year Member
TTMach1 is a glorious beacon of lightTTMach1 is a glorious beacon of lightTTMach1 is a glorious beacon of lightTTMach1 is a glorious beacon of lightTTMach1 is a glorious beacon of lightTTMach1 is a glorious beacon of light
Originally Posted by mffarrell
Since your metal guide tube is in place, you should be able to fit the new GT3 fill tube. As for me, I will mess with it some more. Since I haven’t got a clue how to contort the tube into the oil tank, I may just revert to the stock one.
I just did this. The tank has a notch at the 6 o'clock. The tube has the piece attached to fit into that notch. Thank should help you with the orientation.
Old Apr 1, 2022 | 01:47 PM
  #50
mffarrell's Avatar
mffarrell is infamous around these parts
I just did this yesterday, and the notch on my oil tank pipe adapter is exactly at 12 o’clock position. This was my second try. The trick is to point the guide tube pin at the lower fill tube bolt hole, the turn it clockwise to it seats in the notch at the top of the adapter 12 o’clock position.
Old Apr 2, 2022 | 11:51 AM
  #51
TTMach1's Avatar
5 Year Member
That sounds right. The "prongs" are at the 6 notch at the 12
saline
Oct 7, 2015 07:29 AM
JMC8
Apr 8, 2012 03:27 PM
billkam
Oct 12, 2009 08:21 PM
pdto
Aug 31, 2009 07:11 AM
timf
Dec 13, 2008 07:39 PM
