Efr7163 vs gt3586
Old Jul 12, 2015 | 04:10 PM
  #31
32krazy!'s Avatar
Originally Posted by Bader996
Hey guys
Iam installing turbos , the turbos are not even , one is sitting lower than the other , your kind support please . The right one looks higher, what do you think? Headers new . On my old headers and k24 , I had the same problem ( as I have been told when I installed my muffler ) is that normal ?
pics would be helpful
Old Jul 12, 2015 | 04:20 PM
  #32
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Check it out
Old Jul 12, 2015 | 04:29 PM
  #33
32krazy!'s Avatar
if the headers are new and you had the same issue with different headers and turbos it has to be the upper turbo mounts. thats all that holds the turbo on is the upper mount and the header
Old Jul 12, 2015 | 04:30 PM
  #34
Bader996's Avatar
Will check it out
Thanks Steve
Old Jul 12, 2015 | 04:33 PM
  #35
32krazy!'s Avatar
if the upper mounts are all factory and not bent in any way then that may actually be the way they sit. honestly i never really looked at mine from the front when the motor was out. its possible to be like this and make adjustments in the exhaust system to level out the tips when installed
Old Jul 12, 2015 | 05:44 PM
  #36
BLKMGK's Avatar
I agree that 10:1 seems high enough to require E85 but I'm pretty sure Sean runs straight gas on occasion to help clean up the fuel system. With the heat in Vegas that makes me shiver lol. Pretty sure that the EFR wastegates proved problematic at high boost and that he upgraded them.
Overall I really like the EFR concept and want to move to those once I've got a motor that can handle it and wring out my current turbo. I'm watching with great interest to see what he comes up with for upgrade packages!
Old Jul 12, 2015 | 05:49 PM
  #37
BLKMGK's Avatar
Turbos are going to be positioned by the header aren't they? The turbo hard mounts to it right? There may be support brackets to relieve weight from the header but they shouldn't change the height.
Old Jul 12, 2015 | 06:10 PM
  #38
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
stock header geometry with the efr turbine housing will have the compressor cover touching the tires, which is why we made our own turbine housings
Old Jul 12, 2015 | 06:29 PM
  #39
itguy's Avatar
Looks like you have the black market kit with headers looks like a bad boob job
Old Jul 12, 2015 | 06:30 PM
  #40
32krazy!'s Avatar
bad headers maybe never met a bad boob!
Old Jul 13, 2015 | 07:53 AM
  #41
Bader996's Avatar
Iam happy everything is good and it did fit , the car belong to a friend in Qatar
Old Jul 13, 2015 | 09:58 AM
  #42
lol
#TeamAIM
Nasser
Jan 1, 2013 12:22 PM
