Ohlins DFV + Tarett Drop Link = Binding & Bending?
Old Apr 29, 2015 | 06:50 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
^ Thank you. Call up Tarett. They will insist it's not their fault, they've never heard of the issue, and it's installer error. And you're only the 3rd person on this forum active to respond within 24 hours with the exact same hardware setup and problem.
Old Apr 29, 2015 | 06:55 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
I sent the pictures to them tonight and will follow up in the morning
Old Apr 29, 2015 | 07:14 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Originally Posted by rxbike
Mine are also bent, just got home and this is what I found
You are using the Ohlins mount as well right? We have similar set up minus I'm using the Tarett mount that came with the extended drop links with no ill effect such as bends at all. I was using the Tarett extended with mount on my double adjustable JRZ's as well for a long period of time.
Old Apr 29, 2015 | 07:20 PM
rxbike's Avatar
Correct, i'm using the Ohlins mount. Even spoke with Ira Ami @ Tarret and asked if I needed any special mounts and he read never mentioned their mount
Old Apr 29, 2015 | 07:35 PM
Correct, i'm using the Ohlins mount. Even spoke with Ivan @ Tarret and asked if I needed any special mounts and he read never mentioned their mount
This is what I've been using. It came with the mount. I've ran it on two different set ups.
http://www.tarett.com/items/996-997-products/996-997-suspension/996-997-swaybars~drop-links/996-986-front-drop-link-set-EXTFDLNK-detail.htm
Old Apr 30, 2015 | 08:53 AM
rxbike's Avatar
From Ira @ Tarret:
Yes, I’ve recently been working with a customer that appears to be having the exact same problem. It looks to me like the link is hitting the bracket. Is that correct, or is it also hitting the wheel carrier, or both? On the turbo cars, the link needs to be connected on the inner side of the bar to clear the wheel carrier. Also, please let me know what bar you’re using?
My bracket design has some clearance added to better clear the link. If your link is hitting the bracket, I have a spacer that I think will help.
I’m happy to work with you to help sort this out. Let me know what you think by email or feel free to give a call tomorrow.
i will get the car back to my wrench and have them put it up on rack to confirm his questions. Stay tuned
Old Apr 30, 2015 | 09:37 AM
rockstardoc's Avatar
rockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to behold
Very interesting! So you kept the Tarett links but you just spaced them out? We have 2 washers on ours and still hitting - any idea how many spacers were used or the approximate adjustment needed?
Sorry, I wish could be of more help. My previous installer ran out of ideas and I gave up on the Tarret extended drop links after 2 bent links. I gave it another shot with GMG Motorsports who ran into the exact same problem. They told me they used the "appropriate spacers" to solve the issue.
Tarret obviously has a great reputation within the Porsche community, so that's why I went with them. However, my experience was not quite the best. They kept saying it was an installer problem. However, once the troubleshooting issues were resolved, I am very happy with the setup.
Old Apr 30, 2015 | 11:27 AM
daedalus's Avatar
From Ira @ Tarret:
Yup that's what he told my installers. That's why we have our's installed on the inner side of the bar. It will buy you more space but not enough to prevent hitting. I have my guys source a high strength upper top bolt so we can use more washers to bring it out further and hopefully clear.
Old May 1, 2015 | 11:36 AM
rxbike's Avatar
I keep thinking how spacers would decrease the load of the sway bar when it is twisting going in and out of say a driveway. From my pictures of where the bends of both sides are occurring, this seems the weak point.
Old May 1, 2015 | 12:48 PM
daedalus's Avatar
Picking it up today. Ended up having to put 6 spacers/washers at the top to get the required clearance.
Old May 1, 2015 | 12:52 PM
rxbike's Avatar
Is this with mounting to inside of sway bar ?
Old May 1, 2015 | 03:53 PM
daedalus's Avatar
Yea mounted on the inside.
Old May 2, 2015 | 08:17 AM
rxbike's Avatar
Ira is sending us new arms and spacers and we will attack them in Monday
Hopefully will be up and running by Thursday when I'm back from Florida
Old May 2, 2015 | 08:29 AM
daedalus's Avatar
^^ What setting do you run on your front bar? Middle?
Old May 2, 2015 | 09:30 AM
rxbike's Avatar
I'm running stock bar in front and Eibach in rear in medium
